RTi 8 Bi-Wiring
Rrascal
Rrascal Posts: 15
edited December 2009 in Speakers
I'm after some information about bi-wiring. I have a pair of RTi-8 speakers, driven by a Perreaux PMF 1050 Power Amplifier, with a Denon PMA-1500R Integrated Amplifier used as pre-amp. The Denon is also driving a pair of Klipsch Synergy speakers. Both amps have A & B speaker outputs, and I am using all of them with each individual cable having it's own post. I have recently aquired a Perreaux E110 Power Amplifier, which I wish to use instead of the PMF 1050, but it only has one pair of output posts. Does it make any difference if the speakers are wired to 2 posts rather than 4 at the amplifier end, yet still bi-wired at the speaker end? What difference does bi-wiring make? :confused:
I'm using a Thorens TD-160 turntable, fitted with a Bang & Olufsen SP14 cartridge, and a Denon DCD 685 CD player. I like quality gear, but I'm on a limited budget, so much of my equipment is second hand! ;)
Post edited by Rrascal on
  • george daniel
    george daniel Posts: 12,096
    edited November 2009
    If I were you,I'd just replace the jumpers on the RTI's with some good wire and get on with it.Just my .02. Good luck. Have fun
  • Rrascal
    Rrascal Posts: 15
    You mean like this? (If the pic loads) Lol
  • george daniel
    Yep-- thats what I did with mine--see how you like it-- then if you want to experiment with bi-wire--have at it.BTW--you can make a set for little money,,dress em' up and they look nice-- spend the money you save on gear/music.Have fun.
  • Rrascal
    Rrascal Posts: 15
    yeah I made these up myself, cost me $90 NZ to make two 5m leads, bananas both ends.
  • george daniel
    Well,, how do they sound compared to your original setup?BTW--welcome to the forum.
  • mrbofus
    mrbofus Posts: 297
    hello,
    i have rti8s as well, trying to follow all this bi-wire stuff to no avail.
    What does this achieve??????
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
    Onkyo DX-C390 CD Changer
    POLK RTI8 Mains--Cherry
    the rest...in process...slowly!!
  • olilugo
    olilugo Posts: 405
    Rrascal wrote: »
    Just for the record this is not bi-wiring.
    All you did is to replace the jumpers that suppoesed to be in place when only two of the biding post are being used.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • mufsoman
    mufsoman Posts: 636
    I had my Rti8's biwired and definately heard an improvement in the sound. However, I began to notice comments in several threads about using wire jumpers instead of the crappy metal jumper plates. I tried this and got the same sound as bi-wiring. IMO, save the additional lengths of speaker wire and use short speaker wire jumpers instead of the crappy metal plates. My 2 cents
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • mrbofus
    mrbofus Posts: 297
    mufsoman wrote: »
    Does that really help in sound quality. It looks like a simple fix. What is best to use for a jumper? If it makes a difference I may give it a try.
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
  • mufsoman
    mufsoman Posts: 636
    Others may be able to comment more on specific wire sizes. but i use 12 ga throughout my system and used the same 12 ga wire for the jumpers, very similar to the picture attached above. As always, try it determine what sounds best to your ears.
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • MLZ
    MLZ Posts: 214
    I have RTi8's bi-wired using Canare Star Quad 4s11 with my Onkyo A9555 integrated amp and heard no difference. Wondering why, I looked at a wiring diagram and saw all bi-wiring effectively does is move the jumper from the speakers to the amp. But I also no advantage to return to conventional wiring so I am still bi-wired.
  • Rrascal
    Rrascal Posts: 15
    olilugo wrote: »
    Yeah, I know. Had them bi-wired from Denon PMA1500R amp, but Perreaux E110 power amp they are currently connected to only has two pairs of outputs, not four.
  • Rrascal
    Rrascal Posts: 15
    Thanks for the welcome, George. I admit it, I can't really tell any difference in sound from bi-wired to replacing jumpers. It looks to me like all bi-wiring achieves is a doubling of cable to the speaker, with maybe a slight drop in resistance? Even on an amp with two pairs of output posts, power is still coming from the same two transformers... I imagine a noticible difference would only be heard if bi-amping, where the output from both transformers in the amp could be seperately wired to each of the inputs on the speakers. I've increased the size of my speaker wire in any case, gone from 16 gauge 4 core to 12 gauge 2 core.
  • Boomer Tug
    Boomer Tug Posts: 6
    My research on the web indicates that bi-wiring can produce very marginal improvements. The theory of operation has nothing to do with resistance of the wire, rather, I understand it is all about inductance.
    Parasound P/HP 850 Preamp
    Pioneer SG-9800 EQ (vintage!)
    Rotel RB 981 Amp
    Definitive Technology Powerfield 1500 Sub
    Polk Audio RTi-A9s
  • george daniel
    I tried bi-wiring and finally opted to go with just some high quality wire instead.I could not hear a difference that was so compelling to keep the bi-wire.YMMV--have fun and good luck.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Rrascal wrote: »
    This is the best way to do it if on a budget ;) I would however try putting the cable's to the bottom first.
    I'm pretty shure we all know this by now :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Rrascal
    Rrascal Posts: 15
    Have changed things around several times... Tried bi-amping for a while, but Denon is rated at 70w RMS per channel, and Perreaux is rated at 100w RMS, and tests at 132w RMS, so I thought that was a bit too much difference. Had Perreaux driving the bass, and Denon connected to midrange/treble. The main noticable difference was a lack of volume compared to driving them solely with the Perreaux, due I assume to the lower power amp driving the upper range. Have gone bi-wire now, RTi8's driven by the Perreaux, Klipsch's driven by the Denon. Sounding good... Especially vinyl!!
  • Rrascal
    Rrascal Posts: 15
    edited June 2015
    Polks now bi-amped with two Perreaux E110 power amplifiers. Noticeable improvement in sound qualty, clarity and separation bi-amped.
