LSiC vs. CSi40
wallstreet
wallstreet Posts: 1,405
edited September 2003 in Speakers
Why is the LSiC $100 more than the CSi40? I quick review of the specs show that the 40 goes as high as the LSiC and the 40 goes lower than the LSiC. You get 6 1/2" drivers in the 40 and only 5 1/4" drivers in the LSiC. The only difference I can account for the tweeter difference. Is the ring tweeter worth $100 more? Has anyone A/B tested these speakers? Since there's a Great Indoors close by and with CC moving Polk speakers like they had the plague it looks like a good buying opportunity for one of these speaks?
Post edited by wallstreet on
  • fireshoes
    fireshoes Posts: 3,167
    The CSi40 does go quite a bit lower than the LSiC. However as far them having the same higher frequency range, that's a good example of why we don't buy speakers or recievers based of the specs. The LSiC just has a more refinied sound. I love mine. It was an enormous upgrade over the center in the RM7600. I do wish they would make a bigger one though. I want my center speakers to cover my whole tv (a 51" widescreen). :)
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Forget the specs, tonal signature and quality of components used is what you are paying for.
    Cheers,
    Rooster
  • Airplay355
    Airplay355 Posts: 4,298
    agreed, specs are nothing, go listen to them side by side. specs arent really nothing but they arent as valuable as going out and doing an A/B
  • Tour2ma
    Tour2ma Posts: 10,177
    Yeppers... spec's have a place, but speaker selection is where they have the least impact... IMO.
    More later,
    Tour...
    Vox Copuli
  • STUFFMD
    STUFFMD Posts: 381
    I'm running the 400i in my setup with my LSi 9's. I thought the Lsic was thin and weak compared to the 400. About the only thing I might do is someday replace the 400's tweet with the Vifa. Other than than I thought the 400 had far more realistic sounding voices , a lot more impact and presence. I have heard other people say that the LsiC sounds wimpy. Some have replaced the crossover, The best idea I have heard is to use the Lsi9 for a center.
    My 2 Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
  • Mazeroth
    Mazeroth Posts: 1,585
    STUFFMD. Whereabouts in Ohio are you located? Am dying to audition the LSi9s but no one within 1.5 hours from me has them. I'm in Youngstown/Warren area.
    Thanks!
  • mantis
    mantis Posts: 17,312
    The cs series matches the rt series and the Lsi goes with the Lsi.........what is the question?
    What is the point of your question?
    What speakers do you own?
    If you have Lsi then LsiC is your game.......
    If you have rt series then CS is your game....simple.
    Dan
