Need speaker binding posts at amp end
heiney9
Besides Parts Express where do suggest I look for speaker binding posts which I need to replace on the amp end.
Here's a photo
I found these at Parts Express, but they are for speakers not nec for the amp. Are they the same? The only difference after opening the amp up is these have a male quick connect blade. They might be too long, not sure. Also are the mounting holes universal?, etc. Any help or suggestions greatly appreciated.
TIA
Here's a photo
TIA
Post edited by heiney9 on
H9,
The post hole size is usually, but not always the same. In addition, some use holes that are not round, but have flattened edges so the post has something to grip on and not rotate. Some others solve that with an extra protruding notch on one side. You could add a notch if needed but hard to add material back in to have the two flattened sides.
Another good place to look for nicer posts is from Sonicraft...
http://www.soniccraft.com/index.htm
Hope you get that amp all fixed up and nice and pretty again on the rear end!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
Did you try contacting Dared CS and ask them what posts you have installed?
IF it was me I would want the replacements to match.
Who knows, the might even send them to you.....??
As far as those Dayton Post I "think" they are the same ones that Rich uses in his Carver amp upgrades, so they must not be too bad (I asked him cuz I have a Older Carver I am upgrading)
I am also looking at theses from eBay, but I can't attest yet as to the quality, bu the price is right....
http://cgi.ebay.com/3PAIR-Home-Theater-Tube-AMP-Spade-Fork-BINDING-POST-BRB_W0QQitemZ120491192143QQihZ002QQcategoryZ109438QQcmdZViewItemQQ_trksidZp3286.m7QQ_trkparmsZalgo%3DLVI%26itu%3DUCI%26otn%3D3%26ps%3D6 -
you could get that same insulated gold-plated binding post for less than $5 a pair here.
I used these, fairly short, nicely made:
http://www.diycable.com/main/product_info.php?cPath=26_136&products_id=606 -
2nd the vote for vampiire.JC approves....he told me so. (F-1 nut)
I have used the above PE ones on speakers and they work great. I haven't used and Cardas or Vampire, but they were the best binding posts I'd used to date.
Guys, the idea of Vampire or Cardas is a great one but 1) I only wanted to replace the broken ones 2) keep them looking stock 3) not pay an arm and a leg.
I found (2) pr. from China and they are the *exact* same binding post. I paid $14.99 shipped. Yeah I cheaped out, but this is a secondary rig and I'm not even sure if it's going to work out at this point.
Thanks for all the suggestions
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
