Need help with speaker selection
ScottyB
ScottyB Posts: 2
I have a dedicated mediaroom that's about 17'x22'. The room is wired for 7.2 surround. I was initially going to go with a pair of TSi400 for the fronts and four TSi100 for the sides and rears. I've recently installed a CS10 center and a PSW110 sub (the other speakers currently in the room are an old Pioneer "theater in a box" set that I will be replacing). I'm really happy with these first two speakers. I'm thinking about using TSi100 or TSi200 for the fronts instead of the TSi400 (it's the economy, you know). My question is if I use TSi100 or TSi200 for the fronts, would it be overkill to use the TSi100 for the sides and rears? If so, what would be recommended as an alternative? Thanks in advance for any advice.
Post edited by ScottyB on
    edited November 2009
    Welcome to Club Polk!
    I would recommend the upper level TSI-200s or even the smaller tower 300s....
    No it's not overkill to use 100s all the way around....but you might want to consider the space-saving OWMs at least for the Back Surrounds because they're easy to wall mount and they'll save you some space....you could go OWMs all the way round if you want to wall mount and that would be OK too as long as you keep the Fronts (L/C/R) all in the TSsi line....(TSis and CS10/20 center)...
    cnh
