LC265i Enclosures
Hello, I am curious if any one has installed the LC265i in-wall speakers and if they have used the enclosures for these speakers? Is it recommended to use the enclosures, or is it ok just to install the speakers without.
Post edited by ScottMead on
Hi Scott,
Perhaps these links might be of interest:
http://www.polkaudio.com/forums/showpost.php?p=398348&postcount=5
http://www.polkaudio.com/forums/showpost.php?p=181216&postcount=30
Larry -
I installed the LC265i speakers with enclosures and I am very happy with my choice. The enclosures are very large and require a lot of work to the wall to install, especially if you use one for the center channel as I did. I had to do a major remodel of my wall to accomplish this but it was well worth it. It sounds great and looks simple with all the gear I have. Good Luck and here is my set up.
http://www.polkaudio.com/forums/showcase/view.php?userid=94368My System - http://www.polkaudio.com/forums/showcase/view.php?userid=94368
Fronts & Center Polk LC265I w/enclosures
Surrounds Polk LC80I x4
Sub Velodyne DLS-5000R
TV Sony KDL-52XBR6
AVR Onkyo TX-SR876B
AMP Emotiva UPA-7
Power APC AV H15BLK
Remote Harmony1
Blu-ray Panasonic DMP-BD35
DVDR Panasonic DMR-EZ28K
VHS/8mm Go Video GV-8020
Multi-room Audio Russound CA4 x2 with 8" Monoprice speakers
Amp Wiring Homemade Monoprice 12/2 with heat shrink & GLS Locking Bananas
