rti7's, rti5's vs rti10's, rti8's, and Csi a6 vs Csi5
hey guys, i am looking to setup my first home theatre, but i am on a budget and want to get the best bang for my buck, how does the older rti series compare to the current one, if i can save a few hundred dollars getting them is it worth it? i'll probably pair it with a new sub though, maybe the micropro 3000 or is the 1000 enough, also maybe the 600 pro? and maybe some rti a1's for rear? how does this sound?
Post edited by jerjon7 on
What's your budget?
and how big is your room?panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
15X15 and 1000-1200 for speakers, all your help is appreciated
i am fine with refurbs as well
Ebay-Polk Direct is awesome...Bought most of my speakers on there and they are basically brand new. If I had it to do over again I would go with the RTi A9, CSi A6 and FXi A6 surrounds with an SVS sub. Thing is I have never heard any of these but with the reviews all of these get I don't think you or I could go wrong.
TV: Samsung LN40A550
Mains: Polk Monitor 70's
Center: Polk CS2
Surrounds: Polk OWM3's
Receiver: Onkyo TX sr705
BDP: Sony S350
Subs: Velodyne VRP1200 and VRP1000
Monster Power Conditioner EP IR 2450 -
is there a big difference between lets say the rti8's and the rtia5's?
and the big question is, is there a big difference between the CSi5 and the Csi A6? -
For the most part...no. I've heard both, but I've never compared them side by side. The A5's are perhaps a tad warmer...but that may have been my imagination. Like I said, I haven't compared them side by side.
The aesthetics of the RTiA's are much better IMO. I like the curved cabinet design a lot.
Essentially, they're the same speaker though.
The same goes for the CSi5/CSiA6.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
thanks i appreciate your opinion
i have RTI6 front with CSIa4 centre.. they sound pretty much the same, but the new series (RTIa, CSIa) look much nicer with the grill off.Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
I agree with Curt, have the RTi-10, demo'd the RTi-A5 in home for a month. The A5's are a bit warmer, had more midrange and IMO are much better looking. However you can get some smokin deals on the older series if you are patient and I am happy with mine. I think you will be happy with either set of series.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
That's not really a fair comparison IMO. The RTi8's are warmer than the RTi10's, just as the A5's are warmer than the A7's. It's due to having two midrange drivers. FWIW, IMO the 10's/A7's have kind of a withdrawn mid-range anyway...they're also a touch brighter in my experience.The nirvana inducer-
I've noticed the apparent lack of mid-range on the RTi10s as well. I believe this is mainly the result of inferior amplification. They were being driven by an AVR in the store. I could only imagine that with a separate amp these speakers will open up in the mid range.
To the OP, what do you plan on using for amplification?Proud SOPA Member since 2005! -
just my receiver for now, pioneer elite vsx-21txh, maybe a amp later, any suggestions on that?
