Passive Radiator Repair
JayCee
Does anyone know how to/have experience repairing the driver fabric on the reverse side of the driver? I just purchased a pair of 1Cs and one of the SW-120 PRs has dis-bonded from the styrofoam. I've re-foamed Infinity speakers using a kit, but this is a first.
Thanks in advance for any help or suggestions.
John
John
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Post edited by JayCee on
You may be better off finding another one on ebay. I've seen them there fairly frequently.
stubby
Matter of fact, check the flea market right now!SRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
As I stated to John in a PM, I know these are repairable with the right glue, but I don't recall what it was. I suggested that he start a thread with the hopes that someone would chime in that does remember.Political Correctness'.........defined
President of Club Polk -
Thanks stubby and Jesse. Another member PMd me and he has the match I'm looking for. I still would like to repair the driver. Would be a shame to not try.
John➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I had to repair one of mine that did the same thing and used normal Elmer's glue, it worked like a charm, do not use anything toxic as it will dissolve the foam. Just be careful not to get it on the spider.
The kit I used to repair my Infinity surrounds appeared to use Elmer's glue, too...so, is probably a safe bet and not heavy enough to change the characteristics of the driver.
Not sure if you can see in the pictures, but the webbing tore in spots and when I push the driver in it doesn't make contact. Did you have problems aligning yours? If I didn't have the tears it would be easy to do. I believe I can do a small section at a time, but I'm afraid it may not align properly and cause the front plane of the speaker to list one way or another. Another issue is trying to hold down a small section of the spider at a time in order to make contact but not glue itself to whatever I might devise to hold it. Does this make sense?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
yes it does, lay it face down flat on the table and the weight of the frame should make the cone/foam move back to the spider and be in proper alignment. Try and stretch out the spider so it appears to be as normal as possible and apply glue around the foam where it comes in contact with the spider and the small tears if you have and small holes of missing material take some TP or paper towel in small strips and fill the holes. use several coats of glue allowing time to dry. You should pull the other passive to make sure your gluing in the correct area if you cannot tell for sure where it was. And yes mine did tear but not as bad as yours, the trick was making the cone move back to the spider evenly after that it was glue dry glue dry then it was fine.
Did you talk to Polk CS yet?
I suggest getting some similar type of styrofoam and trying different types of adhesives to see what works. I imagine the Elmers would crack eventually. Something that stays more flexible may be better. An epoxy may also work. I used epoxy to reattach the spider to the metal basket frame on a Polk car speaker successfully.
StanStan
Main 2ch:
HT:
Other stuff:
Epoxy is not a good choice at all, it will melt the Styrofoam as it heats up to cure.Political Correctness'.........defined
Thanks for the tips.Did you talk to Polk CS yet?
Stan
Good suggestion. I'll see if they have recomendations.Epoxy is not a good choice at all, it will melt the Styrofoam as it heats up to cure.
My experience with Epoxy is the same, it can be very caustic. Probably best used on metal.
Thanks everyone for the assists.:)
Elmer's is plenty strong for this application and it does not really need to be flexible as this is the spiders job. Just trying to find something that will not melt the Styrofoam is tricky.
Isn't it funny how the simplest things are sometimes the best option?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
I had to do a repair on one of my 1Cs, used styrofoam glue from a fabric shop. Looks like elmers. Held just fine.Speakers: SDA-1C (most all the goodies)
