C-J MV-52...bias problem
starkiller
Finally got all my tubes installed and went to bias the 6ca7's and have run into a problem. Locations 5 & 6 biased fine but 7 & 8 won't. The red light will not come on whether i turn the screw all the way clockwise or counterclockwise.
Suggestions??
Suggestions??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
not familar with that amp,, whar did you have in before? were you able to bias them? Have you tried swapping the tubes? Maybe a bad bias resistor?JC approves....he told me so. (F-1 nut)
