How to make refrigerators quiet
iskandam
iskandam Posts: 704
edited May 2010 in DIY, Mods & Tweaks
My HT is in the living room, which shares an open space with the kitchen. The fridge is an old GE model located 15 ft away from the couch. Problem: it's loud.
I tried to measure exactly how loud it is from the sweet spot, but the RS SPL meter only goes down to 60 dB. So definitely less than 60 dB but loud enough to be a problem when listening to music/movies. I've been racking my brain on ways to reduce the noise this thing's been making. And no, I will not consider buying a new one. It has been running perfectly for 16 years and I will keep it until it dies. That money would be better spent getting a bigger HDTV :)
An idea that I've been toying around with is to install a couple of layers of roofing felt on the recessed area that the fridge is in. It has good dampening properties and it's cheap.
Another idea is to isolate it from the floor with something like Herbie's Little Fat Glider.
Any thoughts on which method is better, or if there are more effective ways of doing this?
Post edited by iskandam on
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited November 2009
    Just unplug it :cool:
  • jimsvm
    jimsvm Posts: 307
    post some pics of the back of that energy sucker.might help
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • dane_peterson
    dane_peterson Posts: 1,903
    Is your refrigerator running?
    Better go catch it!
  • Systems
    Systems Posts: 14,872
    Testing
    Testing
    Testing
  • NJPOLKER
    A lot of great ideas!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • iskandam
    iskandam Posts: 704
    I should add that I typically listen in the 65-70 dB range for both music and movies. When a lot of stuff is happening in action movies (85-95 dB peaks) of course the fridge is a non-issue, but during regular dialog scenes the hum is really annoying.
    The DIY acoustic treatment thread has motivated me to start my own DIY project. I'm currently doing research on it and hope to get started next month. Before that happens I'd like to fix this loud fridge problem first.
    That vocal booth idea is pure genius, although unfortunately there's not enough room in the recess to accommodate it :D I will post pictures of the recess area and back of the fridge later today
  • madmax
    madmax Posts: 12,434
    Just unplug it +2
    Vinyl, the final frontier...
  • lukewayne
    lukewayne Posts: 80
    Try to figure out what component of the fridge is so loud. Maybe it's two parts hitting each other or a loose screw.
    Maybe you can just replace the offending part? Or dampen it. Becareful not to trap excess heat around the heat exchange coils or you'll end up with a very inefficient fridge.
    My guess is the sound is coming from the compressor. Which unfortunately is probably the most expensive part.
    Good luck
    ________________________________
    Panasonic TH-50PZ800U; Sony BDP-S350
    Sony STR-DA5400ES; Carver TFM-55
    Carver TFM-35; Carver A-500x
    Sony Playstation 3; Custom HTPC
    Polk Monitor 10B Front; 2xPolk CS350LS Center;
    Monitor 5B rears (RB0194-1 Upgrade);
    Velodyne VA1012XII sub
  • iskandam
    iskandam Posts: 704
    By far, unplugging it has been the most effective solution, but the food needs to stay cold so that can't happen for too long :D
    This is what the fridge + recess area looks like:
    The noise is coming from the bottom, which is where the fan and compressor are located:
    1. Compressor
    2. Stock dampening material
    Is there a special dampening material for refrigerators or am I good just replacing it with something like dynamat? I'm thinking of doing this for both the compressor and the fan. If that's still not enough, I may cover the wall behind the fridge in the recess area with a couple of layers of #30 roofing felt.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Clean it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • jimmydep
    jimmydep Posts: 1,305
    Time for a refridgerator upgrade if you ask me.
  • kcoc321
    kcoc321 Posts: 1,788
    Here are some isolators designed just for appliances, made of Sorbothane.
    http://www.vibrationsolution.com/onlinestore.html
    +100 on unplugging it....hehe but I get that is only short term.
    How about some Black Hole Isolation sheets only the back wall?
    Also add some better isolators on the compressor.
  • ben62670
    ben62670 Posts: 15,969
    See if you can find a timer that will turn it back on in an hour. The temp drops very slowly in a full fridge;)
    Ben
  • beardog03
    beardog03 Posts: 5,550
    sounds like the compressor is making the noise..
    make sure everything including all lines are strapped down and tight
    freon may be low, that would make the pump work harder
    Instead of putting a bunch of coin into fixing it, spend 25-50 bucks a month and get a new silent one
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    nooshinjohn Posts: 25,988
    would it make a difference if he put spikes on it and perhaps used Mortite to seal it? It might just help with the bottom end and bring a bit better definition to the ice maker.
  • ben62670
    would it make a differnce if he put spikes on it and perhaps used Mortite to seal it? It might just help with the bottom end and bring a bit better definition to the ice maker.
    Well you finally made me laugh with you:D
    Ben
  • zarrdoss
    zarrdoss Posts: 2,562
    Its 16 years old, its getting louder because it is going out, maybe tomorrow or 10 years down the road but it will keep on getting worse unless something is done. 16 years is allot to ask on an electrical motor and compressor unit, I would replace it so you don't come home to a frig of food gone bad because it died IMO. Newer ones will save you money on electricity in the long run anyway.
    But you might try looking and listening to it when its running and see if something is rattling and try and isolate it with some silicone or bungee cord, be careful not to shock yourself and good luck, I hate noisy refrigerators
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Move the fridge outside.
    Better yet, sell the fridge and put it towards that new HDTV you mentioned.;)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • NotaSuv
    NotaSuv Posts: 3,871
    madmax wrote: »
    Just unplug it +2
    LOL had this very same annoying problem, and it was in a rental so had to keep it...I used one of those "clappers" to turn it off during extanded TV watching, worked great,,clap it on, clap it off :), ours was just an older noisy unit...
  • BIZILL
    BIZILL Posts: 5,432
    my fridge is quite quiet. that is, until the automatic ice maker breaks the ice. man, when i first got it on a quiet night when not a creature was stirring, not even a mouse the thing made this tremendously loud CRACK sound that scared the pee outta me. i did the whole flinch thing where you turn around to check the noise with your heart racing and a natural fist flying in the air. LOL.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • HHStuart
    HHStuart Posts: 263
    Refrigerator noise bothers me too but in this case I would replace the refrigerator.
    New refrigerators are so much more efficient than 16 year old ones, that it would pay for itself in a couple of years. The new one would be a lot quieter. Just my 2 cents.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
  • Libertyc
    Libertyc Posts: 915
    A new energy star refrigerator would be much quieter and you will save you money.
  • iskandam
    iskandam Posts: 704
    Well, i'm not ready to give up on it yet so I'm going to give that Silent Feet thing a shot
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Apples to oranges comparison here, but it might be food for thought:
    I installed 2 large computer-type cooling fans on the back of my entertainment center. They ended up being quite loud, and the cabinet itself acts as a resonator, and amplifies this a bit. When I built my diy acoustic panels, I put a 2'x4' panel mounted horizontal behind the tv. I was surprised how well it absorbs the fan noise! I will be looking for some quieter fans, but for now, it's completely tolerable.
    If you have enough clearance behind your fridge, I'd order a panel,(or make one) and give it a shot.
  • iskandam
    iskandam Posts: 704
    It's pretty tight back there so a 2" thick panel is not a realistic solution for me. But if the Silent Feet is not good enough by itself I may stick several layers of Fat Mat/roofing felt/B-Quiet/eDead/etc. on the wall directly behind the compressor and fan to absorb the noise.
    That having been said, I'm also planning on putting a DIY acoustic panel behind the TV/rack/center channel to cover the first reflection from the center channel!
    treitz3 Posts: 20,085
    Could you please describe the sounds that are coming from the lower area? Also, how long / how often do these sounds happen and are they the same as any noise that may be constant?
    You can start by taking the hottest water you can stand, a good cleaner [I use vinegar for this], an absorbent towel and clean both sides of the seal for both doors. Make sure to dry them thoroughly. When the doors are shut again, check to make sure that they are completely sealed. An hour or so later, unplug the fridge.
    Next, you will need to vacuum out all of the dust around the bottom of the fridge. Wipe up anything you can get too after you vacuum. If you have one, take a coil cleaning brush and clean the coils as best you can. While you are down there, check for anything that vibrates or is the source of noise. Tighten down anything that appears to be loose.
    Reassemble the fridge and plug it back in. It should at the very least run more efficiently after this, lowering the noise level and lowering the cycles of cooling.
  • iskandam
    iskandam Posts: 704
    The fridge runs on a cycle. It goes on for several minutes then off, then on again. Of course it's dead quiet when it's off, but when it's on the fan and, or, compressor, creates this loud, constant humming sound. No rattling. Doesn't sound like anything is loose at all.
    I did vacuum most of the crap that's been collecting in there for the past decade or so when I took those pictures. Actually my PC tower also makes that same humming sound.
    I just picked up a roll of PEEL & SEAL from Lowe's. Tomorrow I'm going to line the inside of the PC case with this stuff first to see if it'll get the job done.
  • ben62670
    I have used peel and seal for deadening with decent success.
    Ben
  • jimsvm
    jimsvm Posts: 307
    You can add more sound damping matteral to where it is now. Do not block off condenser fan air inlet.(bottem right from the back).For all reading this thread, dust bunnies on condensers=money out the window,and premature death to compressors.Long live the dust bunny the refrig guy says$$$$.
  • iskandam
    iskandam Posts: 704
    I just finished lining the inside of my PC case with PEEL & SEAL and... it made absolutely no improvement at all :( I mean I used up 2/3 of the roll and even double, triple, and quadruple layered on the sides. It sure added mass but did nothing to decrease the humming even a bit.
    I'm not going to bother wasting more money on this crap material. Silent Feet ordered.
