stupid question
No need to replace your wire, it doesn't go bad. If it's oxidized, you may want to clip a inch off the end and expose fresh wire, I've never had to do that though. Wire will last longer than you will.
I agree not one reason to change your wire. Also I use monster cable speaker wire and works just fine.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
so since solid wire (like that used in your homes electrical system) doesnt have the up keep of speaker wire why not use it instead of speaker wire????
(pretty sure i know the answer but just wanna here it from one of yall, prob has something to do with resistance and signal clairity but what do i know
no one gonna chime in ????? lol -
Just bought 2 monitor 50's to replace ages old fishers, I read this thread and saw a reference to the second set of posts and bi-wiring.
does this mean I can rig a second system to them?
thanks
paul
PS - AGGHHH my brain - just found a thread that "Explains" Bi-wiring and Bi-amping" my brain is about to explode! I am going back to play with building computers as a hobby - much easier to understand.
are you all audio engineers?
