Does one or two DB of Efficiency make a difference?
Say 90 as opposed to 88 or 89.
Also, what exactly is efficiency.. I assume it has something to do with how well it uses the power its recieving.
Post edited by KeithV on
Efficiency and sensitivity are sometimes used interchangebly by different manufacturers.
"Sensitivity: Measure of the sound pressure level generated at a distance of one meter from a speaker when the speaker is fed a 2.83 volt signal (1 watt at 8 ohms); efficiency of a speaker creating a certain sound pressure level from a given input with high figures representing a more efficient speaker."
Assuming the same measurement techniques for two different speakers, a 3dB increase in sensitivity will halve the power requirement to play at a paricular SPL. In other words, if my speakers are rated at 91, and yours are rated at 88, I will need half the power you'll need for the same SPL.
It will make a difference in the volume the two speakers will produce given the same gear/power. -
Sweet, the R50s are sounding like a great bang for the buck deal. -
I like the Old Klipsch's ratings....
102db+ Nominal! Man i tell ya, when you hear 115+db from two speakers and still sounds sweet......that sorda changes your expectations of a speaker....lol
to bad I don't like the Klipsch sound eh...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What that sounds like is called uncomfortable. Klipsch are way too sharp for my ears, screw that horn loaded thing, I need to hear.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
