Aquired original SDA SRS
    F1nut Posts: 52,000
    edited November 2009
    Out of curiosity, what other amps have you pro amp lovers used on your SDA's?
  • Hamatym
    Hamatym Posts: 269
    My set-up has made every Polk speaker I put on it sound incredible. The bigger the Polk, the better of course. Here is what I have:
    - Samson SX1200 Amp
    - DBX IEQ-31
    - Gemini PA-7000 Pre-Amp (very simple version)
    I got nice XLR cables to connect everything up, and feel you will not find a better or cleaner sound anywhere else. Especially since you can control the output levels with the EQ to produce the exact sound your ears prefer....I like other systems as well, but this is hard to beat for the total price tag.
