RTIA9's and Monitor?
cstmar01
cstmar01 Posts: 4,424
edited November 2009 in Speakers
I recently picked up a pair of RTIA9's that I will be using as fronts, replacing my monitor 70's. Before I had a CS2 upfront for the center. Do you think I would really need to upgrade to the CSi A6, or do you think the CS2 would be able to keep up? I read down the spec sheet and they are pretty close to being the same. I'm running them off a Emotiva XPA-1 for the RTiA9's and an XPA 3 for the center. So my center is lacking in terms of watts compared to my mains which are at 500W's each, but didn't know if upgrading would be really worth it for the center.
Thanks!
Post edited by cstmar01 on
  • Krazyz1
    Krazyz1 Posts: 256
    Bi-wire your A9's and re evaluate. Made HUGE difference on my system
  • leroyjr1
    leroyjr1 Posts: 8,785
    You already spent a bunch of money on the Emo amps and rti a9's so you might as well finish it the right way and get the CSI a6. Yes you can get by with the CS2 but the csi a6 matches perfectly.
  • Pycroft
    Pycroft Posts: 1,961
    It probably won't be THAT much money if you sell the CS2 to fund the upgrade.
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • cstmar01
    Thanks guys, I will probably upgrade sometime soon and sell off the CS2 or just keep it for a 2nd system in my bedroom, which would work just fine in there. I just didn't know how much difference it would really make in the long run.
    and what are you using for Bi-wiring cables? DIY? I've heard that Bi-wiring doesn't make a lot of difference but have never tried it and seeing what bi wires are going for, such as Signal, etc. I didn't know if it would be worth trying. I just didn't want to get some and then have to turn around and get rid of them right away if I didn't like it. I know I could probably make some myself but just don't know when I'm going to find the time. :(
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    If you'd like to try Bi-wiring without going broke have a look at the Canare 4s11 bulk cable and terminate it yourself ;)
    Let us know how those a9's sound with the xpa1's would ya?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • leroyjr1
    Tried bi-wiring and didn't notice a difference.
