Preamp with HT bypass
Pycroft
Pycroft Posts: 1,961
edited November 2009 in 2 Channel Audio
Hello all...
In my quest to build a good system that incorporates both HT and 2 channel sound (For budget reasons mostly), it was suggested that I get a 2 channel preamp that has HT bypass. In searching other forums, I've found a list of these:
BAT VK3i
Musical Fidelity A5 -
Musical Fidelity A3.5
Musical Fidelity older models as well
Krell 300xi & 400xi (Various Integrated Models)
Plinus 8500 or 9200 - I think have HT Bypass
The ones I've found info on are 1,000 + dollars. I was hoping to find an option for less money. Would anyone share options I may have for good 2 channel listening at a reasonable price (No budget set now, but I'd say in the 300-500 dollar range is about it for now). My current system is below:
HK AVR 354
Polk RTA 11TL's
Polk CS400
Polk Monitor 30's
Def. Tech Prosub 800
Soundcraftsman PCR 800 amp (2x205 watts)
Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • leroyjr1
    leroyjr1 Posts: 8,785
    Adcom GFP-750 is very popular and said to be a great Pre amp for the money. They can be had for around $700 and has HT bypass.
  • Jetmaker737
    Jetmaker737 Posts: 1,123
    Here's a list I compiled form other sites (no claims to accuracy since I haven't had time to look into all of them):
    Abrahamsen Audio PA-1
    Abrahamsen Audio V3.0
    Adcom GFP 750
    Advantage S2
    Arcam Alpha 9C
    Arcam FMJ C30
    Arcam FMJ C31
    Atoll PR300
    Audio Analogue Bellini
    Audio Analogue Maestro Stereo Line Preamplifier
    Audio Research SP16L
    Ayre K-5xe
    bel canto PRe1
    Bel Canto PRe3
    Cambridge Audio Azur 840E
    Cary Audio cpa 1
    Cary Audio SLP-2002
    Cary SLP03 (tube)
    Cary Audio SLP-5
    Chapter Audio Preface
    Class
  • Face
    Face Posts: 14,340
    Goldpoint can make a passive with HT Bypass for you.
  • Pycroft
    Jet -
    That's a GREAT list, and a nice starting point. Anyone have comments on any that may be able to be had on the cheap (Budget constraints) but be a decent find.
    Thanks,
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • thsmith
    thsmith Posts: 6,082
    Thanks Jet, half way toying with getting a tube pre to replace my adcom gfp-750 and it will have to have HT bypass.
    heiney9 Posts: 25,491
    thsmith wrote: »
    Do what I'm doing, running the tube pre thru the HT bypass...........well of course unless you need the HT bypass. :p
  • danz1906
    danz1906 Posts: 5,144
    The Adcom GFP-750 is a good one, I have a Primare Pre-30,its a lil warmer
    sounding that the Adcom pre.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Systems
    Systems Posts: 14,872
    A good pre amp sans the bypass mode should be reasonably transparent enough to allow you to run your front L@R ht outputs into one of the pre's aux inputs without much in the way of signal degradation.Then the pre's volume can then be set to a level predetermined by your calibration so levels will be correct.I do this with mine and it works fine.
    The Hafler SE100 and the newer version the 915 are good budget choices if you can find one.They use discrete jfet gain stages instead of cheap IC opamps.
    Testing
    Testing
    Testing
