Ford 5.4 litre spark plug problem
joeparaski
joeparaski Posts: 1,865
edited November 2009 in The Clubhouse
A heads up to you Ford owners. Make sure you put anti-seize on the spark plug threads when you change plugs (if you can get them out). These plugs use a 14 mm socket and they don't look like your usual spark plug. They tend to get stuck in the head and they break apart, leaving part of the plug in the thread hole, requiring the removal of the cylinder heads (ShopKey labor time puts it at 25 hours for the job).
Ford has changed the design of the plug from the original and has a special liquid you spray in the spark plug holex to help free it up before removal, which doesn't always work btw.
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
    VR3 Posts: 29,417
    edited October 2009
    another tip - change the plugs at 60,000 instead of 100,000
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Even if there was not a problem with the spark plugs breaking or stripping the threads out of the head it is still a **** of a job to even get a socket onto the plugs much less get them out or back in.
    Been there done that.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Best common sense right here. :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • raidersrule76
    raidersrule76 Posts: 471
    Yea and your also lucky if they don't just blow the plug right out of the hole going down the road seen that happen too. You can usually fix it the first time with a heli coil if your lucky but it will do it again and then you are **** out of luck new head not cheap either.
    Mark
    Sig to be updated after dealing with the insurance company:(:(:(
  • Systems
    Systems Posts: 14,873
    That sux. I thought the Hemi was hard enough to change the 16 plugs it has.
    Testing
    Testing
    Testing
  • ohskigod
    ohskigod Posts: 6,505
    Add the 4.6 to that list as well. my Mustang was made right on the us of the design change so I have no ida if I will have that problem or not, the dealer will be doing it anyway.
    I dont think I will even go to 60000 before a plug change since I put so few miles on it (bought it in 8/07 and have about 6500 miles on it)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • sucks2beme
    sucks2beme Posts: 5,682
    Old 4.6/5.4 problem was not enough threads holding it in.
    It sometimes blew out a sparkplug. I've had two blow out on the 98 f150.
    Fix, forget heli-coil, use Quickserts. They will last. The new design
    has threads, and a new problem. There are new procedures and tools to help.
    http://www.denlorstools.com/autoblog/2008/11/ford-spark-plug-removal-tool-picture-of-fords-bad-design/
    VR3 Posts: 29,417
    disneyjoe7 wrote: »
    Ford says you can keep them in there 100,000 miles.
    But that is asking for trouble.
    VR3 Posts: 29,417
    I had the spark plugs replaced on my truck at around 104,000 (I hope that was not the first change) but it went very smoothly!! :)
  • Serendipity
    Serendipity Posts: 6,975
    How many miles do you have on the truck now?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Rivrrat
    Rivrrat Posts: 2,101
    I haven't even figured out where the plugs are on my 05 F-150 yet. But, at 34k, I have a few yrs to worry about that.
    My equipment sig felt inadequate and deleted itself.
  • thsmith
    thsmith Posts: 6,082
    98K on my 01 Expedition 5.4l, had plugs replaced and no issues at 104K.
  • sucks2beme
    thsmith wrote: »
    2001 had the old heads. Those were the ones that blew out plugs.
  • sbpolk
    sbpolk Posts: 644
    I have an 05 Expy Eddie Bauer on lease, that is going back in December. Last week my wife was driving it, suddenly began running very rough, CEL light started flashing, and nasty stench. She was less than a half mile from home and limped it into the garage. I am scared to find out what's wrong with it.
    We leased it new, changed oil every 3-5k, driven gently and never had a single issue with it. It currently has about 52k on it, and I am afraid I will be putting a new engine it it just before turning it in at the end of the lease...
    Ridiculous.
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
  • Rivrrat
    sbpolk wrote: »
    Ridiculous.
    That Kind of sounds like the catalytic converter to me.
  • thsmith
    sucks2beme wrote: »
    With 6K on new plugs and 104k overall I am not worried.
  • sbpolk
    sbpolk Posts: 644
    Rivrrat wrote: »
    Wow, that would be great...
  • joeparaski
    For those of you who replaced the plugs....did you do it yourself? If not, was it "actually" done or not? I say this because the customer we had with this problem said that his Ford dealer replaced the plugs 40,000 km ago, with an invoice to prove it. BUT...the plugs were NOT replaced, they still had the little white paint spot on top which denotes that it is the original plugs from the assembly line...plus, they sure didn't look like 40k plugs either.
    Joe
    Joe
  • Serendipity
    I personally would replace them MUCH more frequently.
    How many miles do you have on the truck anyways?
    If I were you I would be interested in the past owners' service records, to determine if/when they were replaced before you got the truck.
    VR3 Posts: 29,417
    In 04 Ford totally redesigned the 5.4 liter and you were pretty much guaranteed some problems if you waited until 100,000 to change the plugs. The guys that did it at 60,000 usually turned ok. If the plugs didn't shoot through the top, they broke off when taking them out.
    I have not heard any problems with the 4.6 liter after 04 having this problem.
    There is a lot more to a car than oil changes every 3,000 miles.
    My truck is clicking on to 135,000 and counting.
    Zero problems other than window regulators (two). Common problem for my model year.
    But I am maintenance nut.
    Every 3,000 - Oil/filter change + fuel injector cleaner
    Every 30,000 -
    1) Front differential fluid
    2) rear differential fluid
    3) Power steering flush
    4) radiator flush
    5) fuel filter change
    6) pvc valve change
    7) throttle body / fuel injector cleaning
    8) transmission fluid change
    9) check belts and hoses (replace as necessary)
    Every 60,000 -
    1) spark plugs
    I drive my truck hard --- and it has given me no real problems. (knock on wood)
  • Serendipity
    Every 30,000 -
    4) radiator flush
    6) pvc valve change
    Every 60,000 -
    1) spark plugs
    What about...
    1. Bleed Brakes
    2. Lubricate Chassis
    3. Trans filter?
  • concealer404
    concealer404 Posts: 7,440
    This kindof makes me glad that i destroy plugs on my DD, so i just change them every time i do an oil change.
    VR3 Posts: 29,417
    of course I change the trans filter when they change the fluid. that would be silly not to.
    I have them check the brakes. There is nothing to lubricate on this truck. It uses "lifetime" parts. I do have them look over the cv joints and all that good stuff.
    What are you changing spark plugs in every oil change??
  • concealer404
    1990 MX6 GT.
    I can't get plugs in as cold a heat range as i really need, so they don't last long.
  • Serendipity
    Nope, but from what I understand the newer cars use platinum tipped spark plugs so they can go a bit longer.
    Personally, I would change regular spark plugs at 30k / platinum plugs at twice that. Waited too long for the first change and got a "check engine" light. Next time will be in 30k, definitely!
  • Serendipity
    Trey - I guess you do the following stuff yourself?
    1. Change oil and oil filter
    2. Replace Air Filter
    3. Top off brake fluid
    4. Add/flush power steering fluid
    5. In-Cabin Microfilter
    6. Battery Fluid
    7. Transmission Fluid Change
    8. Flushed Radiator, bleed radiator
    9. Bleed Brakes
    Saved me a lot of $$ compared to going to the dealer.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    joeparaski wrote: »
    This is a common problem on any engine that has aluminum cyl. heads. You've got two dis-similar metals, and there is a chemical reaction to the steel by the aluminum. It corrodes at the threads, effectively 'shrinking' the hole around the spark plug. A lot of times the softer aluminum gives way and the threads strip out. Maybe they should just heli-coil the heads at the factory and save the mechanics a step.:D
    Caution should be used to not over tighten the plugs when using anti-seize. Lubricant (anti-seize) changes the torque values.
