New PC advice please
mikewilkinson
Hi all.
With Uncle Kevs moolah, I am looking to get a new PC (this one wont open MS Word...). Below is what I am looking at. Please give me some advice on whether you think they are alright (and if all the parts would all work together). In both builds the case, keyboard, mouse and speakers are fairly generic.
PC 1. INTgamesEL
MOBO: Intel S775 Gigabyte GA-EP43-UD3L
CHIP: Intel Core 2 Duo E7400 (2.80GHz/45nm/1066FSB/3MB) LGA775
RAM: Desktop DDR2 Ram 2GB Kit (2x1024MB) PC8500 1066MHz Kingston HyperX KHX8500D2K2/2GN 5-5-5-15
VID CARD: PCI-e (nV) 9500GT 1GB Sparkle SF-PX95GT1024U2-HP (550/800MHz)
HDD: 3.5" HDD SATA-300 500GB 16MB Seagate (7200rpm)
DVD: 5.25" SATA DVD Buner/Rw Samsung SH-S223-BL 22x Black (oem)
MONITOR: WideScreen LCD Monitor 19" ASUS VH192D (5ms)
PSU: Power Supply 650W Coolermaster eXtreme Plus RS-650-PCARE3-AU (with SATA Cable)
PC 2. AMD
MOBO: AMD AM2 S940 Gigabyte GA-MA770-DS3P
CHIP: AMD AM2 Athlon 64x2 Dual Core 6000+ (3.0GHz/2MB/89w)
According to itestate.com.au the prices for the above would be PC 1: $1054 and PC 2: $952
Thanks in advance.
PC 1. INTgamesEL
PC 2. AMD
Thanks in advance.
Post edited by mikewilkinson on
I'd spend the extra $, and go w/ the intel set-up. I have a gaming pc, almost the same as the AMD you listed, and I wished I had spent the $ for intel.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Try newegg.Those prices seem a little high.....You should also consider a little more powerfull power supply.850watt at least.You just may thank yourself in a year or two.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
SpammerPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
So Las, did you report the spam? He's showing up all over with his junk links.
