Just picked up an Adcom GFA-5800 (broken)
IMO it is not necessary to replace the 244,s if the they are good, I would just buy a few extra 9240's and install the 8 closest matches.
I agree. It is more important for each bank to match than to have the banks match each other.
Ben -
I'll start with that first then, that'll save a few bucks--Newark has plenty of the 240s in stock so..
I sent Newark an email asking if they can match, or at least pull from the same date codes. We'll see.
I'll be placing my order tomorrow after I hear back from them.____________________
Pool: Atrium 60's/45's -
disneyjoe7 wrote: »Ok the cost to fix this amp....
Sorry I been an electronic repair person, your amp IMHO is NFR "Not Feasible to Repair"
B..)
Yeah I'm not sure I'd go much higher that about $225 for parts, but its still a fun project either way so I'd be getting some satisfaction and learning experience out of it.
If this were at a repair shop and that was just the parts costs and I still had to pay for labor??? No way. At least this way I'm doing the labor and it seems likely these parts will fix it.____________________
They don't have the 244s anyway--I'd have to go with the schematic value of the 240's.____________________
IMO it is not necessary to replace the 244,s if they are good, I would just buy a few extra 9240's and install the 8 closest matches.
Yep! Sounds OK to me too.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I gotta ask! Are you sure that's all it takes to fix the 5800? I would check the driver board too just to be safe.
When you are testing the amp, use the VARIAC if you have one. Or use the 100W light bulb in series to the power plug (to limit the current input to the amp).Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
What wattage rating should I get for the Zeners?____________________
Good advice and IMO it is almost essential.Also be sure the bias is set correctly and checked several times after the amp has had ample time to warm up.
When you are testing the amp, use the VARIAC if you have one.Testing
Testing
Testing -
Zeners have part numbers. What does it say in the manual or schema you got?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
I don't have a VARIAC so what I have done is use 2amp FB fuses in place of the larger rail fuses.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yep the current rating will be correct if you use the correct Zener part #.Zeners have part numbers.Testing
Testing
Testing -
Well, I'm basing that assumption on the fact that the other half of the channel and all the other components on that board test OK, also I did have it powered up already. Looking at the schematic the damage doesn't go all the way back, and it appears that the source of the failure may have been a short at the binding posts or speaker wires somewhere. So I'm more hopeful more than anything. At least I'm not dealing with any ICs or logic gates here....When you are testing the amp, use the VARIAC if you have one. Or use the 100W light bulb in series to the power plug (to limit the current input to the amp).
No Variac.
How do you do the Light bulb hookup thingy?____________________
Doh, I type my thoughts so slow, 2-4 responses get in there before I hit Post.
Any suggestions on a decent Variac?
Sounds like a useful tool, especially with anything AC related--I never liked working with full AC and the sudden hums, pops and then the subsequent dimming of the lights on the whole block
. ____________________
Your probably aware but just a reminder that Mosfet's are sensitive to and can be damaged by a static charge,handle with care.Testing
Testing
Testing -
Not sure if you can see the detail it he schematic above but it only says 8.2v. Nothing about a part # or wattage rating. I'll have to see if I can see a # on the part--but they are pretty small. I don't have the servioce manual--Only the schematic above and a small section of the service manual that provides the Bias setup instructions.
How does one determine if the existing resistor is non-inductive? Apparently this makes a difference in this kind of circuit...____________________
yep--although I never really got why storing them in styrofoam was a good idea. I mean I do but then again I don't - if you follow me.
At work I'm a big fan of antistatic precautions--people always walking around, esp in the winter, with hard drives or memory chips in their hand exposed. :mad:
Some people don't understand that static doesn't always kill right away, but that it can weaken a part for failure later, and when it does fail they don't realize it was because of the static damage they did awhile back.____________________
Thanks GV! Excellent point about biasing adjustment.I don't have a VARIAC so what I have done is use 2amp FB fuses in place of the larger rail fuses.
I think $100 for a reasonable Variac is a good start instead of spending a few bucks for 2 amps fuse everytime it blew.Well, I'm basing that assumption on the fact that the other half of the channel and all the other components on that board test OK, also I did have it powered up already. Looking at the schematic the damage doesn't go all the way back, and it appears that the source of the failure may have been a short at the binding posts or speaker wires somewhere. So I'm more hopeful more than anything. At least I'm not dealing with any ICs or logic gates here....
No Variac.
I am thinking it would be OK too but you really need to check and make sure the driver stages are OK. At minimum, I would check to make sure there is no high DC V (should be only a few mV) at the Gate of the MOSFET. It seems like a good start without having oscilloscope.
The light bulb needs to be hooked up in series to the live wire of the amp plug. If you have an old light bulb socket, use one end of the wire in series with the live wire of the amp, use the other end to plug into ac outlet. Use 100W or less light bulb. The light bulb should dim after a few seconds when the caps are charged and if there is no short between transistors or any mishaps. If the light bulbs never dim after quite a few seconds, there may be a short somewhere.
Ok, there is limitation - there are amplifiers that consumes 200W or more at idle power so using only one 100W light bulb does not really work and the light bulb may never really dim. You'll need to use two or more of light bulb and sockets in parallel to increase power (more watts) in series with the amp ac plug.Any suggestions on a decent Variac?
Variac is very useful and pays itself off in a couple of years of regular use. You can find one on eBay or in many electronics store too. But make sure it's rated for at least 500W or more.Your probably aware but just a reminder that Mosfet's are sensitive to and can be damaged by a static charge,handle with care.
Yippie! MOSFETs are super sensitive to static discharge.
I can't tell you what it is from looking at schematic you posted there but there will be the parts list in the manual and you can look up the part number in the parts list (Bill of Materials) to determine the part number for zener.
Some Wirewound resistors could be inductive if the wattage is too large but I don't think you need to worry about it as long as you put the replacement with the same wattage.yep--although I never really got why storing them in styrofoam was a good idea. I mean I do but then again I don't - if you follow me.
The power MOSFETs may be a bit more forgiving to the static discharge than smaller MOSFETs but I would wear wrist wrap and grounded my skin (and body) before I even touch it.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
$100 added to the cost for a VARIAC, or $2 worth of fuses? I would like one, but for just a few minor projects it may not be worth it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I like the VARIAC or light bulb in series for testing anything which can be powered up and blow something else. The VARIAC can be reused where the fuse isn't
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Because its FUN to have lots of TOOLS!!
I see that there are tons of them on ebay, but what about these new models? OK or Stay away?
http://cgi.ebay.com/Metered-Variac-Variable-AC-Output-Transformer-20-Amp_W0QQitemZ220493162905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item33566aa999
http://cgi.ebay.com/Metered-Variac-Var-AC-Output-Transformer-5-Amp-NEW_W0QQitemZ220493162683QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item33566aa8bb____________________
Anatech over at DIYAudio recommends against the Light bulb idea, although I've heard several comments on using one:Quote:
I would definitely recommend making (and using) a dim bulb tester to avoid mass destruction at the first power up.
No.
Some amplifiers can become unstable doing it this way. Also, if you do have an open gate stopping resistor, everything might be coming up just fine - then sudden failure with all the smoke and flame one might expect. That's because an open gate can (and will) float with an indeterminate voltage, until it strays into a hard on state. Very high conduction that tends to destroy the opposite polarity devices.
I think I might just get a Variac--even if I only use it seldom____________________
Chris (Anatech) is top notch and knows his electronics, I'd listen to his advice."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Yes using dimmer, but a bulb is fine in my mind. Not as handy as a VARIAC but handy yes, dimmer NO.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Well, light bulb idea is something that you have to make do with where resources are scarce and not available. But it requires more tinkering and needs very good understanding of how things really works and knows the limitations and few exceptional cases (the ones like Anatech suggested).
Variac is very nice tool to have if you don't mind spending a few coins. I would get one myself I don't have one yet.
http://www.circuitspecialists.com/level.itml/icOid/9441
Find yourself a nice one and get a gift from them when you spend over $50 bucks (surely in your case).Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Ben,
The idea of using Variac and Light bulb in series or fuses are not the same and does not work the same.
Variac limits the voltage to the device under test (DUT) so it'll protect the DUT while you make some critical measurements from the components. Thus, it allows you to troubleshoot problems and keeps the DUT from possible damages.
Variac can also be used to reform old electrolytics caps in the old and unused amplifiers and bring them back to life safely (but this method is not always successful to reform electrolytics and replacement is always better than reforming).
Lightbulb idea is very similar to Variac but it limits current (not voltage) so it'll still protect the DUT but has limitations. It's something you need to use only if a Variac is not available.
Fuse Only protects for a short time and blew so you can't really troubleshoot anything if it blew.
But if you use the Variac like once a year, may be you don't need one and better send the broken item to the Tech for professional repair.
Yep! The guys in DIYA knows their stuff and have many many years of practical experience that money can't buy or learn in school.
I would definitely listen to some gurus from DIY and AK.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I've followed Chris's posts for a long time and he has helped me with some specific questions so I know he's one of the good, no BS types that post over there.
P.s. and he knows Adcom, Carver, Nakamichi forwards and backwards"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Yep! the only reason I like AK and DIY. Less BS over there.
The folks there don't answer to the posts they don't know answers to. They simply ignore your post but you don't get the wrong info either which I think is a good thing.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Ben,
I am not disagreeing with what you are saying, but for people who do this once in a great while they become dust collectors. Again if the fuses are low amp pieces that cost next to nothing to use, and they don't blow with a true power on with (like flipping the power switch) then you are good. So say you do get a VARIAC and you power it up slowly I would still use lower amp fuses till truly tested good. Again you still should use some low amperage fuses for testing. Those output trannies are not cheap. Bottom line when it comes to amp repair listen to Chris(anatech) over anyone here.
Ben
