Best "all-in-one" amp kits
Systems
Where can I find the best all in one amp kits? Should I buy each part separately (ie. Power wire, fuses, etc..) or should I just buy an amp kit?
I need to hook up three amps.
Thanks for any help.
Testing
Testing
Testing
Testing
Testing
If your going to hook up 3 amps..best to buy your stuff individualy. Most kits wont meet your needs..
good luck:cool: -
Goto www.speakerhole.com.
Here, they have a 4 gage amp kit. the only thing I would swap out of this kit is the fuse under the hood. I would replace with a circut breaker.
Scott
