rti8 build guestion
dave shepard
I was just at J&R's web and seen the rti8 and in the spec. it says it has 1-1in. tweeter and 1-6.5in woofer but in the pic. there seems to be two 6.5's. is the pic. right or the spec.? is this going to replace the rti70?
Thanks Dave
Thanks Dave
It has 2, will replace the RTi70- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
