Polk/B&K
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    smglbrth wrote: »
    I've decided to sell some things and might sell more pending... (say tuned)
    Second is my B&K Reference 200.2 amplifier. This is not the Series II. Power ratings in 8 ohms/220 watts/channel. Into 4 ohms/325 watts/channel. Damping factor of 450 with 75 amps/current. I am the second owner. The front face is near perfect as is the rest of the amp. On the Audiogon scale I would rate it at 8/10 because I am the second owner. I also have the original box and manual. One of the speaker terminal screws tends to slip out of it's plastic sleeve at times but I never had a problem with it. Tighten your grip on it when **** it down, problem solved. This amp weighs almost 40 pounds without the box. I will ship this amp but remember, it does weigh that much. $400.00 plus shipping.
    If there is no interest in either of these for a week I'll try other avenues.
    I am currently using a Sunfire Signature 405 X 5...Would this B&K be better or sound better?? Does anyone have any experience with both that can tell me how they compare?? My front 2 are SDA SRS 1.2tl's.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • smglbrth
    smglbrth Posts: 1,496
    edited October 2009
    Vmaxer - Sorry but this amp is now off my "for sale" list. I forgot to post this on this certain posting but did on the other one that just had this amp without the speakers. Sorry about that. Besides, this is just a 2 channel amp, not a 5 channel. From what I hear about the Sunfires you should just keep it and enjoy!
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    Thanks for the response. I did realize that the amp was a 2 channel, was just going to drive the 1.2TL's with it. I would still like to know how it compares to the Sunfires if anyone else should have experience with them....:confused:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
