Subwoofer Adapter Cable
Ohioste
Ohioste Posts: 204
edited October 2009 in Speakers
Hello again all.
Had a friend buy a new receiver and we are trying to determine if there is an adapter to where you can plug speaker wire into a subwoofer input.
I looked on monoprice but couldn't find anything that I believe would work.
Anyone know of anything or any solutions?
Your help is appreciated.
Thanks,
Ryan
Post edited by Ohioste on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Should have speaker wire input's on the sub?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    If it's a new reciever, it should have a sub out...
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Hey Ryan,
    some subwoofers have what are called "speaker terminal inputs/outputs" used as an alternative method of connecting a subwoofer to a receiver (and letting you connect rear/satellite speakers to the subwoofer as opposed to running long speaker wires from receiver to speakers+subwoofer cable).
    As far as looking for an adapter I don't know of any really. Does the receiver have preamp outputs? You can run those to the subwoofer's RCA inputs.
    Otherwise, the receiver should have an LFE OUT i.e. subwoofer pre-out for connecting a subwoofer.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Ohioste
    Ohioste Posts: 204
    edited October 2009
    Alright thanks...he's got a HTIB speaker system and upgraded his receiver. His receiver has the RCA jack type for his sub...but the sub itself has the + and - for speaker wire.
    I wasn't sure if there was anything out there to where you could hook them up.
    Thanks for the help.
    Ryan
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited October 2009
    That is one of the main problems with upgrading the AVR in a HTIB setup. Some times the sub doesn't have the same connections that the AVR does, esp. if it is an older HTIB. Looks like it is time to get a new sub, and the journey begins, lol.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Face
    Face Posts: 14,340
    edited October 2009
    You wouldn't get any sound, you need either an amp or a new sub, preferably the latter.
