Vacuum tube dampeners - DO they work?
thsmith
thsmith Posts: 6,082
edited October 2009 in DIY, Mods & Tweaks
Looking for feedback from people who tried Tube Dampeners.
Are the Silicon O-rings better or worse than purpose built dampeners ?
Let me say that I do not hear anything that would make me think I need them.
Post edited by thsmith on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Worked extremely well for me, especially since I don't have my amp sitting on anything special (that or my stand is just a bit too sensitive). Here's my amp with its tubes+dampers.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2009
    Bob Carver said he tried them but found no difference; his best experience was with tubes that had a HEAVY glass base where the filaments go through. He said they were most effective at curing microphonics/resonance. This makes sense from a physics standpoint as it's most likely the mettalic parts vibrating that are the cause rather than the tube shell.'
    I'm sure someone will disagree, but I don't really give a **** and that's my $.02~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • thsmith
    edited October 2009
    Thanks guys.
    SO far 1 for and 1 does not need.
    Any other feedback ?
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    Yes. They're not very expensive so I'm not sure why it matters anyways. I wouldn't care what Bob Carver thinks either.
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2009
    I bought some and they make a difference-they are not a cureall but for like $20 a set (or less), why not?-Its not like its $500 Magic pebbles or anything.
    Check out Herbie's Audio Lab.
    ____________________
    Pool: Atrium 60's/45's
  • thsmith
    edited October 2009
    Doro, are your referring to o-rings or something like Herbie's ?
  • dorokusai
    edited October 2009
    I've always used Herbies stuff....probably have a dozen or so in my goody box.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited October 2009
    http://herbiesaudiolab.home.att.net/
    Spending a little cash will give you a piece of mind if nothing else. Thats what I did. I bought four dampers and moved on.
    Don't forget to wear gloves while installing them.
  • mmadden28
    edited October 2009
    Herbies has several kinds avail, including the silicone rings
