2 DAC's
Systems
Systems Posts: 14,873
edited December 2009 in For Sale (FS) Classifieds
First is a Monarchy 18b with piggyback DAC chips. Silver face and can be used as a preamp. Has fixed and variable outputs with volume knob. Excellent reviews. $375 shipped
Next is a MSB DAC with outboard power supply. Accepts analog as well as didgital inputs. $300 shipped OBO
Testing
Testing
Testing
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    Im interested in the 18b and will let you know in 24 hours.Im waiting on a model 10b preamp cost.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • roscoeiii
    roscoeiii Posts: 48
    edited October 2009
    Can you provide some details on the MSB DAC?
  • Systems
    edited October 2009
    From my files on manuals:
    This 24 bit/192 kHz) Digital-to-Analog converter offers professional studio performance. Using the Link DAC instead of the inferior DACs in your components will immediately refine and enhance the sound you hear. The Link DAC has the 192kHz sampling rate performance used by studio professionals. The Link DAC III will improve the sound purity of any DVD, CD, LD, and DSS with a digital output. It operates flawlessly at 32, 44.1, 48, and 88.2 kHz as well. MSB’s Link DAC switches between the optical and coaxial inputs automatically. Most other DACs require the user to manually switch inputs. The Link’s analog input pass-through feature creates an extra analog input and allows a variety of configuration options for your system. When no digital signal is present the analog inputs are passed straight through to the outputs. The greater sound detail is the result of very low jitter clock recovery provided by the phase lock loop. Direct coupled outputs provide incredible bass enhancement. There are no capacitors anywhere in the signal path, resulting in a linear response all the way down to DC (0 Hz!). An actively maintained low output offset is achieved through a DC Servo Loop. The DC component of the output signal is continuously corrected to maintain zero volts DC without the use of high loss and sound blocking capacitors. Motorola bipolar output buffers provide the listener with rarely achieved accuracy in sound reproduction. Four separate voltage regulators provide ultra clean power. Heavy duty outboard DC power supply keeps noisy AC out of the unit. The LINK has won an Innovations award and has been rated a Class B Stereophile Recommended Component.
    Testing
    Testing
    Testing
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    Sorry Ill have to pass on the 18b...I won the model 10 pre...Thanks
  • Systems
    edited November 2009
    The 18b is still up for sale as well as the MSB DAC.
    Testing
    Testing
    Testing
  • Peaceman
    Peaceman Posts: 27
  • Systems
    MSB Link III reduced to $275 shipped
    Testing
    Testing
    Testing
