Is Sunfire "Cinema Grand Five Channels" strong enough power LSi15s?
  • love2listen
    love2listen Posts: 172
    edited October 2009
    jimmydep wrote: »
    Where in NJ are you? I'm in 07407. If we are close enough you could come by and listen to both the sunfire and Xpa-5 head to head, or I'll be more than happy to bring the Emo to you, for a head to head on your system. An afternoon of checking out different equiptment.......sounds like fun.
    Jim D
    Jim,
    I am in 08812, which is not too far from you. Your suggestion of an afternoon of checking out different equiptment sounds good to me. We will have to work on the logistics to see what works best. If you wish, send me a PM, letting me know what days work for you and hopefully we can make it happen. Tnx for your kind offer! :)
    Carlos
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2009
    Bernal wrote: »
    Thanks for your reply.
    ¿Can you explain to understand: "...Active/passive, if active, phase relationships, etc."?
    Passive biamping would be simply connecting separate amps to either the upper/lower range (horizontal biamping) or a separate amp in each speaker, one channel driving the upper range and one driving the lower range (I personally recommend this one). In active biamping, you need to remove the internal speaker crossovers & use an active (preamplified) crossover to separate the frequencies. Many passive crossovers have phase adjustments to keep all the drivers in phase, so while removing them from signal path frees up some power, you need to know a lot about the makeup of the original crossovers in order to make everything work properly. Active biamping is MUCH more complicated, but the potential rewards can be greater.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    Enjoy your sunfire, you seem to be having alot of fun lately Bernal---Rock On..
    RT1
  • sucks2beme
    sucks2beme Posts: 5,691
    edited October 2009
    Gee, nobody mentions Outlaw anymore? a 7500 would be a good choice.
    I don't think biamping in a 5.1 setup is worth the effort. A good quality
    amp is going to get the job done just fine. The Sunfire is certainly going to
    to provide plenty of power and has a good track record of being dependable.
    The extra hassle of cabling it all out and expense pretty much means you'd
    be better off spending your money on the better quality amps, source,
    and good cables.
  • Bernal
    Bernal Posts: 991
    edited October 2009
    RT1
    :)Sunfire!!!
  • Bernal
    Bernal Posts: 991
    edited October 2009
    sucks2beme wrote: »
    and good cables.
    Hi,
    What is OutLaw?:confused:
    You can indicate a link.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Bernal
    Bernal Posts: 991
    edited October 2009
  • Bernal
    Bernal Posts: 991
    edited October 2009
    Hi
    Q.- Where is a chronological list of manufacturing models Sunfire?
    Q.- What is the date of manufacture of "Cinema Grand 200 ~ five"; see image in question No. 1?
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2009
    Look on Sunfires website for the answers.
  • Bernal
    Bernal Posts: 991
    edited October 2009
    cfrizz wrote: »
    Search in: www.sunfire.com - http://www.sunfire.com/downloads_archive.asp, but found the model ("Cinema Grand 200 ~ five"; see image in question No. 1).
  • chrisfromalbany
    chrisfromalbany Posts: 41
    edited October 2009
    whats price you can buy a sunfire for?
  • megasat16
    megasat16 Posts: 3,521
    edited October 2009
    Bernal, you can call SunFire and ask them for answers of your Q1. if that's important for you.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • love2listen
    edited October 2009
    If I recall correctly, the first 4-5 digits tell you the month and year that the unit was manufactured. Hope this helps.
  • cfrizz
    edited October 2009
    Check out www.audiogon.com for prices.
  • Bernal
    Bernal Posts: 991
    edited October 2009
    Verificare on the amplifier.
  • Bernal
    Bernal Posts: 991
    edited October 2009
    Finish my stereo system under the following configuration:
    ✓ DENON AVR-4308Ci: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH/2.1 CH A/V
    ✓ SUNFIRE Cinema Grand 200 ~ five - Bob Carver's
    ✓ OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio
    ✓ POLKAUDIO LSi15 LEFT
    ✓ POLKAUDIO LSi15 RIGHT
    ✓ VELODYNE OPTIMUN 12
    Denon + Oppo + Sunfire = give me a good combination of sound ..
    Q.- I like to hear your opinion?
