Reel to Reel maintenance
thsmith
A non-internet friendly friend of mine just bought a Pioneer 707 RtR and is looking for advice on where to get cleaning supplies.
I suspect some of you guys still use RtRs, if so please let me know your sources for supplies.
Post edited by thsmith on
A bottle of isopropyl alcohol and a Q tip to clean the head, a head demagnetizer, a small bottle of sewing machine oil, and a can of dust-off, should take care of most of the maintenance needed for an RtR. Windex works well for the surface grime.
Routine or not-so-routine?
For head cleaning, good quality alcohol (100% iprOH is OK, not rubbing alcohol, though) and Q-tips are fine. He'll want a head demagnetizer, too.
New production tape recording supplies are available from www.usrecordingmedia.com
Beyond that... paging Ken Swauger! :-)
Manuals for the RT-707 are available at:
http://www.hifiengine.com/manuals/pioneer/rt-707.shtml
(free registration required to D/L) -
Thanks guys, I will steer him to the links.Speakers: SDA-1C (most all the goodies)
