Sub wiring.
GWORREL
GWORREL Posts: 1
edited October 2009 in Speakers
Hello
Need help with PSW Polk 350. Have power but no sound. Only wire I see is from sub out on receiver to LFE on sub. Is this right, do I need a special wire for the sub?
thanks
Post edited by GWORREL on
    treitz3 Posts: 19,992
    edited October 2009
    Hello and welcome. No special cable, just an RCA. Are you certain that the AVR is actually sending a signal to the sub? If in doubt, refer to the AVR's owner's manual.
    If you are still having issues, check for a fuse in the sub to see if it is blown.
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Most AVR's have the LFE, sub, port turned off and you have to go into the settings on the AVR and turn it on.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
