Tubes, Tubes and more Tubes
F1nut
F1nut Posts: 51,747
edited November 2009 in For Sale (FS) Classifieds
I've got too many tubes sitting around here, so it's time to thin the herd.
Matched Quad of Ei 6CA7 - $200.00
The two quads above are close enough to be a matched octet, if you need them.
Quad of Ei 6CA7 - $175.00 (for those that don't need a matched quad)
Matched Quad of Ei EL34 - $150.00
3 Matched Ei EL34 - $75.00
Matched Pair of JJ EL34 (Blue Glass...way cool) - $50.00
Matched and Balanced Quad of Ei 12AT7 - $80.00
Matched Pair of Tung-Sol 12AX7 - $20.00
Pair of Groove Tubes 12AX7 - $15.00
Pair of Sovtek 12AX7WC - $15.00
Pair of EH 12AX7 - $15.00
For those that don't know the Ei factory has been closed for years and most Ei's are very hard to find now. Get'em here while you still can.
The prices above do not include shipping, which in most cases should be in the $6.00 range. If you want insurance, that's extra. However, I will not be responsible for squat if you don't take it.
I take PayPal from a bank account only, no credit cards...period.
I will also take a check, but only if I know you. No exceptions, sorry.
Finally, I reserve the right to sell to whomever I want or don't want.
If you have any questions, please ask and thanks for looking.
Post edited by F1nut on
  • skipf
    skipf Posts: 694
    edited October 2009
    F1,
    Got any 6DJ8's or equivlents laying around?
    Skip
  • amulford
    amulford Posts: 5,020
    edited October 2009
    I want the AT7's, give me a call...
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    F1NUT, sent a PM on the Matched Quad of Ei 6CA7.
    heiney9 Posts: 25,430
    edited October 2009
    Damn, missed the 12AT7's
  • Poee7R
    Poee7R Posts: 906
    edited October 2009
    Put me down for the Tung Sol ax7's please.
    Pm Inc.
    Dave
    Once again we meet at last.
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited October 2009
    I'm in. Can you transport to Polkfest?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    Jesse.,
    Will talk to you about the EL34, maybe try something different in the Wolcott...
    RT1
    F1nut Posts: 51,747
    edited October 2009
    Skip, sorry none.
    Antny, yours if you want them.
    Tracy, PM responded to.
    Dave (Poee7R), PM responded to.
    Dave, they are yours delivered to PF, no problem.
    Ted, we'll talk.
    F1nut Posts: 51,747
    edited October 2009
    Ok, Ted isn't taking any of the Ei EL34's as I don't have enough for his needs, so they are still available.
    In case someone doesn't know.....the 6CA7 is a direct replacement for the EL34 with no need to do anything except set the bias as you normally would.
  • thsmith
    edited October 2009
    Skip, sorry none.
    Ted, we'll talk.
    Thanks F1 I will be paypaling you this evening
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Are all of the 12AT7's gone? Would you recommend any you have for my VTL 2.5? I have no idea which would be good or if I even need any but you guys talking about swapping tubes has me interested. :o
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    F1nut Posts: 51,747
    edited October 2009
    Updated info:
    Matched Quad of Ei 6CA7 - SOLD (Still have more to sell)
    Matched Pair of JJ EL34 (Blue Glass...way cool) - to be delivered at Polkfest.
    Matched and Balanced Quad of Ei 12AT7 - I haven't heard back from Antny.
    Matched Pair of Tung-Sol 12AX7 - SOLD
    vc69, the 12AT7's are sale pending, see above. I don't have anymore of those, nor do I have any 12AU7's. What are you running now?
    F1nut Posts: 51,747
    edited October 2009
    Matched and Balanced Quad of Ei 12AT7 - SOLD
    Folks, there's still plenty of great tubes available.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited October 2009
    Yeah but none that I can use :mad:
    F1nut Posts: 51,747
    edited October 2009
    Shameless bump. :)
    F1nut Posts: 51,747
    edited October 2009
    Poee7R and thsmith,
    Shipped your tubes today. :)
  • Poee7R
    Poee7R Posts: 906
    edited October 2009
    Just an excerpt from a pm F1 sent me.
    "Just looked at these again....not only are they matched they are balanced as well, which I missed. I also missed the fact that they are gold pins. Still the same price."
    First class guy here folks, as most already know. Tubes arrived today, overpacked to survive.
    Thanks again Jesse.
    Dave
  • thsmith
    edited October 2009
    Ditto that !
    Jesse, received the tubes, packed to take a beating from a gorilla.
    The 6CA7s perform as you said they would, kicking the SED Wing Cs butt.
    Thanks for the link in your PM, cool site.
  • thsmith
    edited October 2009
    Jesse, the 6CA7s, Sylvania 5751 and mullard CV4003s are sounding great. Anything else you have in the way of tubes your not using that might be an upgrade to the 5751 or mullards ?
    F1nut Posts: 51,747
    edited October 2009
    Ok, another Matched Quad of Ei 6CA7's are sold, so that leaves the following still available;
    I think those are as good as it gets. :cool:
  • thsmith
    edited October 2009
    Thanks Jesse. The 5751, mullards and Ei's are making some nice fire and magic.
    F1nut Posts: 51,747
    edited October 2009
    Since ntrinh03 totally screwed up the Flea Market with 22 BS posts.....BUMP!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    Jesse,
    Anything I could replace tubes on a CJ PV-5 pre amp? Tubes used 5965, and 5751, not in use right now are 12ax7 (used in Phono input).
    Steve
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    F1nut Posts: 51,747
    edited October 2009
    Steve, sorry broham I've got nothing for ya.
  • disneyjoe7
    edited October 2009
    Ok thanks that's cool, just checking.
    Thanks for looking :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    F1nut Posts: 51,747
    edited October 2009
    Well, I do have some green label Sylvania 5751's, but I wouldn't sell them to my enemy. You should look for some yellow label Sylvania 5751's from the late '50's. They run about $100.00 each, none better, IMO.
  • starkiller
    starkiller Posts: 2,723
    edited October 2009
    hmm, wonder how that quad of Ei EL34's would sound in my just purchased c-j mv-52 ??
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
    F1nut Posts: 51,747
    edited October 2009
    What's in it now?
  • haimoc
    haimoc Posts: 1,031
    edited October 2009
  • disneyjoe7
    edited October 2009
    Thanks Jesse for the heads up. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
