Which Polk product?
tomcatcrew
tomcatcrew Posts: 2
edited September 2003 in 2 Channel Audio
Gentlemen,
I'm just getting back into 2 channel and have an opportunity to pick up some previously enjoyed Polk speakers.
I can choose between the RT600I or the R30's
My musical tastes range anywhere from classical to Ozzy
I'll be using a Denon DRA-685 Receiver 100W per side -
nothing fancy - just want the best sound I can get for a reasonable amount
Which is the better choice?
Post edited by tomcatcrew on
    VR3 Posts: 27,967
    RT600i
  • dorokusai
    dorokusai Posts: 25,573
    Welcome to the forum.
    Keep your eyes out for closeouts on the RTi line, beings the new line is coming soon to stores.
    Since you mentioned 2 specific choices, I will recommend the RT600i. It is a more dynamic and capable performer than the R30. The cabinet is more appealing to me personally also.
    Good luck.
  • tomcatcrew
    tomcatcrew Posts: 2
    How long ago did they discontinue thr RT600i and would you say the RT70/100i are significantly better?
    VR3 Posts: 27,967
    The RTi70 is an awesome speaker. I honestly think it is the best speaker in the current RTixxx line. If you have the money I would get the RTi70, avoid the RTi100 as much as you can (unless you can NEVER get a subwoofer in ANYWAY SHAPE or FORM)
    The RT600i is a great speaker though, I believe it was 1.5 or 2 years ago it was discontinued - but still sold recently for 200 bucks or so (new)
  • dorokusai
    There are alot of great deals floating around the internet and local brick-n-mortar stores.
    The RTi70 has a nice following here in the forum, and it is popular opinion that it is a better performer than the RTi100. I would say the RTi70 is the best performer out of those three choices.
