Are your 1.2TL's tweeters wired wrong by factory like mine?
1235»
    Toolfan66 Posts: 17,996
    edited October 2009
    Right 5338
    Left 5326
    Mine are Pin/Blade as well but I am sure mine was 1.2's as they had the SL2000 tweeter's
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    Mine are: left - 6226 and right - 6203. They had the SL3000 tweets when I got them. I have upgraded to the RDO 198's...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    Serial numbers mean very little but its a nice thought.
    edited October 2009
    dorokusai wrote: »
    I figured that, but it would be nice if it told us something. with all the changes that could or will be changed in the vintage polks.
    Years down the road when somebody else ends up with my 1.2's that have been modded to tl's. will somebody be able to tell what they really have?
    Sorry just thinking out loud;)
    not that it matters or that i will really care at that time.
  • RichCanDo
    RichCanDo Posts: 177
    edited October 2009
    Serial numbers dictate which speakers can use or not use the AI1 interconnect for some models. So I would assume the numbers can be related to the time period of manufacture, though maybe not to a specific date.
    Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
    Pre-amp: DBX CX1
    Center: CS1000p Rear Surr.; f/x1000
    Parasound HCA-1205A amp; Center & rear
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
    Tuner, FM: Onkyo Integra T-9090II
    Cassette: Onkyo Integra TA-2090
    VCRs: JVC HD4000U digital, HRS8000U SVHS
    Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
    Conditioning: Monster AVS2000, HTS5100MKII
    F1nut Posts: 51,700
    edited October 2009
    There's a whole lot of over thinking going on in this thread.
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2009
    funny thing is...i've been waiting for YOU to chime in and say exactly THIS.:)
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
    edited October 2009
    I agree with the over thinking, not that it's all a bad thing.
    But I would still like to know that the findings on the wiring from the wire nuts to the crossovers are correct. positive wire nuts go to the positive on the crossovers and visa versa.
    I would like to hear from the SDA gurus here on this matter.
    treitz3 Posts: 19,954
    edited October 2009
    *farts*
  • thejck
    thejck Posts: 849
    edited September 2010
    OK just to summarize again to make sure I understood it all.
    From the bottom we have t1(green, white), t2(yellow, white), t3(blue, white), t4(red, white) with color going to positive or small terminal and white going to larger terminal or negative
    Into the 1.2 TL connector that goes into the crossover starting from the outside of the crossover board we have
    yellow, white(t2), red, white(t3), green, white(t1), blue, white(t3)
    The colors get swapped with their respective whites on the connector if doing the TL upgrade for the 1.2
  • thejck
    thejck Posts: 849
    we have blue and green wires coming out of the connector the blue is positive and green is negative. drivers are marked with a red dot indicating positive.
    drivers are marked using dm1, dm2, dm3 and dm4 from the bottom up
    blue wire coming out of the crossover connector first goes to dm2(+) then to dm1(+)
    green wire coming out of the crossover first goes to dm3(-) then to dm4(-)
    another blue wire starts from dm4(+) then goes to dm3(+) then it goes to dm2(-)
    another green wire starts from dm2(-) to dm1(-)
    this should be the same with 1.2 and 1.2TL
    Just make sure your wires are positive to positive negitive to negitive..
    Not sure why but the 1.2's were wired out of phase. (tweeters)
  • thejck
    thejck Posts: 849
    we have black and white wires coming out of the connector the black is positive and white is negative. drivers are marked with a red dot indicating positive.
    drivers will be marked with sd1 sd2 sd3 and sd4 starting from bottom
    black wire comes out of the crossover connector and goes to sd3(+) then sd4(+)
    white wire comes out of the crossover connector and goes sd2(-) and then sd1(-).
    another white wires comes from sd4(-) and goes to sd3(-) and then to sd2(+)
    another black wires comes from sd1(+) and goes to sd2(+)
  • thejck
    thejck Posts: 849
    I just wanted to get it all written down so its easier for someone following us
    Anyone please feel free to correct me.
    You look good.. I didn't find any drivers wired wrong just the tweeters. I purchased a special tool to pop out the wires in the white block to wire the tweeters in phase.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    Refer to the photo in post #74 as a guide.
    1. Remove the tweeter wire harness connector from the crossover board.
    2. Using the Molex tool, and starting from left to right, switch the blue and white, then the green and white, then the red and white and lastly, the yellow and white. Result: the tweeters are now correctly wired OUT OF PHASE which is exactly how Polk intended them to be.
    3. Reconnect the harness to the xover board.
    4. At each tweeter, only remove the connector from the white wire (negative) and replace with the wide blade connector which will now accomodate the RDO -198 or SL 300 tweeter.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thejck
    thejck Posts: 849
    I think that sums up the wiring part of the 1.2 to 1.2tl upgrade..
  • TrashyTrucker
    TrashyTrucker Posts: 225
    I sure enjoyed this thread! Thanks to you guys for pointing this out... I had to reverse my spades on my RDO's on my 3.1TL's. Im am now safe to say I am politically correct!
    regards,
    Matt :D
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
