Need advise in buying a power conditioner
jolax73
jolax73 Posts: 225
edited October 2009 in Electronics
I am looking to buy a power conditioner. Can anyone recommend what is a good brand and does not cost arms and legs? I heard APC is a good buy, or is there any other brand? Any specific model I should buy? Please advise.
Post edited by jolax73 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Panamax in my experience proved to be very reliable, although I just sold it to a fellow polkie on here. Let me dig up a thread of mine to help you better make your choice.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    I have an APC H15, and i see no reason to upgrade. It DID make a sonic difference, and looks pretty nifty down there. :) The peace of mind is kindof nice, too.
    The H10 can often be found for about $100, and is a great buy, in my opinion.
    Unfortunately, i have no experience with any other units, so i can't help there, sorry.
  • kawizx9r
    edited October 2009
    This helped someone else out less than a month ago, whether or not it'll help you I'm not sure but here. - http://www.polkaudio.com/forums/showthread.php?t=85831
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Pauly
    Pauly Posts: 4,519
    edited October 2009
    Im using a Belking PF30 and has done a decent job thus far. There is one cheap over in the FS section
    http://www.polkaudio.com/forums/showthread.php?t=89593
    Pauly
    Life without music would
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Having owned/used both a power "conditioner" and a "regenerator" both of which are Monster product's, i can honestly say the money is better spent on a regenerator :o Has something to do with a regenerator taking dirty voltage from the wall, converting it and making it a clean + steady 120v :confused:
    I noticed the hts5100 robbed me of my mid's/high's :(
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2009
    I'm using an APC and very happy with the results.
    I tried a Monster and wasn't satisifed though.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    appadv wrote: »
    Why were you not satisified?
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    What is the difference between H10 and H15? Will the H10 be sufficient for my HT setup?
  • concealer404
    edited October 2009
    jolax73 wrote: »
    I believe it's just the total amount of "power" or "current" or whatever it can "condition."
    The number 750,000 is sticking in my head for the H15, and 500,000 for the H10. What the unit is? I'm not sure. :p
    I can look it up later for you, though, if someone else can't chime in better than I. I'm not real great with the technical aspects of all this.
    But yes, the H10 should be fine for your HT setup.
  • anhchungdoan
    anhchungdoan Posts: 760
    edited October 2009
    Go to Vann's web-site. There is enough spec to help you with your decision making. If your voltage fluctuates quite a bit, either the H10 or H15 would be more than sufficient. I like the way they have 3 modes +/- voltage protection.
    The "silver" H10 has been discontinued and was selling @ $99.00 for sometimes which was a steal. There are some on E-bay but they want more than $99.00.
    I have received 2 APC C5 silver form Vann's for $39.00 a piece. I use the C5 for my DVD and BR players. Some protection is better than none.
    I have been using the Monster HTS1000 MK III which is very sufficient but too sensitive with the T-storm and lighting in my area this time of the year. It did its job by shut the whole system down twice last month and I am glad it did so.
  • Serendipity
    edited October 2009
    jolax73 wrote: »
    The Monster did not filter the power as well as the APC.
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    I wonder if I can plug all my 1500watt amp, 50" plasma TV, an AVR and DVD player into one power conditioner such as Belkin PF30 or APC H10? Will it be able to handle it if there is really a power surge? What specs should I be looking at in order to make sure it serves my needs. Thanks!
  • lakesailor
    lakesailor Posts: 319
    edited October 2009
    For the money the APC H10 and H15 simply cannot be beat. I run a Chang Litespeed and tried an APC in a second system and really it is all you need at 1/2 the price of everything else.
  • anhchungdoan
    edited October 2009
    jolax73 wrote: »
    As far as surge protection , the APC H10, Monster, Panamax would do the job just fine. Do not go too much in debate that we lead you to more confusion. Don't worry abt MOV's exploded on you. I have never had one caught on fire or exploded on me for the last 30 some years.
    Read the Manufactures recommendation of the total ampere usage and do not overload the power surge unit. I would not plug the TV in the same unit with the rest of my system but it is just me.
    Most power surge will have some kind of filtering build in as side benefit. Even the co called none- MOVs " Brickwall". Some can hear the difference, some cannot depending on how "dirty" your current is.
    The most praised power conditioner is the Shunyata but I would not touch it with the H/T application. Too expensive for some Kaboom and explosion scennes. For critical 2 channel analog listening, I would.
    Get the H10 and go to sleep with a peace of mind. I have no affiliate with Vann's but with my past experience with them, I highly recommend them.
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    So you are saying, the TV should not be plugged in together with the amp and avr to the same power conditioner?
  • mufsoman
    mufsoman Posts: 636
    edited October 2009
    Ok, I'm kinda embarrassed to ask this, but.......how does a Monster PowerBar 1100 compare to a APC H10/H15. Do I need to consider an upgrade? Will I hear any difference? thanks
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • anhchungdoan
    edited October 2009
    jolax73 wrote: »
    So you are saying, the TV should not be plugged in together with the amp and avr to the same power conditioner?[/Q
    No, I never said that. I prefer to hook up my Tv to another powersurge . As long as , you do not overload the surge protection, you are fine.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited October 2009
    eventually i might get a surge protector...for now it's gonna have to wait.:eek:
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
    heiney9 Posts: 25,510
    edited October 2009
    Because M* products suck. To the OP stay away from M* products......you gear will thank you.
  • sTiLlLeArNiNg
    edited October 2009
    heiney9 wrote: »
    I wouldn't say they suck, just have thing's in the wrong place :o If i knew a lil' more about electronic's i'd try to mod the 5100 but i don't so i can only imagine modifying it lol TBH I think the ferrite core's on the inside of the receptacle's are what kill's the audio but hey what do i know? I'm only a beer drinkin', street hockey playin' Canadian hoser! Back to my IGLOO i go :)
    PS The avs2000 work's mint! :)
    Media Room 7.1
    HTPC
  • skipf
    skipf Posts: 694
    edited October 2009
    I'm using a Belkin PF60 and really like it. If you buy it from an authorized dealer, it comes with a lifetime warranty too.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited October 2009
    Any of the PS Audio products will help you significantly depending on your price range.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited October 2009
    1 APC Brand H10 on the hi-fi gear, and 8 assorted APC Battery Backups on Computers, Cable Boxes and Plasma sets with absolutely no complaints. The H10 was a nice sonic improvement when installed.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • digitalvideo
    digitalvideo Posts: 983
    edited October 2009
    Best power conditioners on the market are the Balanced Power Technology line (BPT)
    www.b-p-t.com
    www.6moons.com/audioreviews/bpt4/plus.html
  • anhchungdoan
    edited October 2009
    heiney9 wrote: »
    Sorry to hear that you disaprove the Monster. I believe they will do what they supposed to do by design as a power surge protection just the pricing is little high.
    I use Monster products on my H/T system that I bought over E-bay at 1/2 MSRP and I am not ashamed using them. On my 2 channel analog, I go to a diifferent route with 20A dedicated lines and Furman products.
    If you want HI-END, go to Shunyata and Bryston web-site and get the one of the best and forget about all the low-end/mid-end hypes. Money can buy happiness in this case.
  • inspiredsports
    edited October 2009
    www.b-p-t.com
    Dang, those things give me power supply envy . . . :)
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited October 2009
    jolax73 wrote: »
    Purchased from a CP member a month ago . . .
    My first impressions are 100% favorable (and I'm going to be more relaxed as I leave my solid state gear powered up 24/7 and used to worry during electrical storms when I was away or sleeping).
    Before I firmed up the buy from criverajr, I went directly to apc.com and downloaded the specs into an Excel spreadsheet to make side-by-side comparisons.
    In the specs, there were only 5 differences, and 2 were in FAVOR OF THE H10 and one was the weight which is a moot point.
    --- The H10 comes WITH a 10' power cord whereas the H15 has no cord provided.
    --- The H10 operates from 5-113 degrees F and the H15 from a narrower range of 32-104 degrees F.
    --- H10 wieghs 16.1 lbs and H15 weighs 16.7 lbs.
    --- H10 is $50,000 equipment protection warranty and H15 is $75,000 (USD)
    --- H10 is 49498 Joules (140kAmps) and H15 is 5270 Joules (160kAmps)
    Unless you require the extra 272 Joules, the H10 is a screaming bargain.
    NAD SS rigs w/mods
    GIK panels
    edited October 2009
    No money doesn't have to be the only way to happiness. Staying away from M* products is the way to sure happiness. Yes, we all know they are over priced, but even if they were free they still come up short.
    edited October 2009
    H15 has a digital display as well. You can;t beat them with a stick if you buy one for less than retail. Great product at a great at a great price! Not the be all and end all of power conditioning/regulating but they perform beyond their price point
  • anhchungdoan
    edited October 2009
    Here you go. Good job. It's $179.00 Vs $249.00 in black. For those who like to tweak around with Power Cords, H15 is a way to go if you have extra money to experiment different Power Cords. Maximum current input 12A Vs 15A , detachable power cord Vs attachable power cord. If you still can get the Silver H10 for $99.00 NIB ( discontinued) and can live with the Silver Color,the H10 for $99.00 NIB is a steal.
