Audio on Single Channel with distortion - Carver CT-17
ActionJaxn
Hi,
I'm wondering if anybody can be any help with my CT-17 Pre-Amp. If I'm in the wrong section, please point the way.
Anyways, the problem is:
I get most of my audio through one channel. The balance knob is adjusted at center so no problem with that. There is no problem with power amp as I have tested with two of them. When I switch the pre-amp to hologram, there is some noise present on the other speaker. The audio will switch to the other speaker when I switch the audio wires. Also, the audio coming over the regular pre-amp channels sounds like I'm getting some distortion. When I switch to remote output, the sound is great, but I have no direct control over it from the front panel switches.
If anybody that can help has suggestions, please let me know. If more information is needed, please let me know. By the way, if anybody has a service manual that they can spare a copy of, please let me know. Thanks.
Post edited by ActionJaxn on
The price is now $200.00.
Rita is not the one fixing the tube gear, that gets jobbed out.Political Correctness'.........defined
President of Club Polk -
Does anybody have a service manual for the CT-17 that they would be willing to let me have a copy of? I feel that this may be a simple replacement of some components, but I have to know what the voltage references are supposed to be at the test points within preamp. I'm not too excited about paying somebody $200 + shipping to fix this pre-amp. Please help. Thanks.
Nothing inthe Servicemanual thats helpful in ur case, but here it goes. U gotta be a member there http://thecarversite.com/specs/specs-carver.aspx
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50 -
Why would you say there is nothing in manual that will help? Do you have previous experience in repairing a CT-17? Thanks for any info.
