Down firing versus front firing
Karzai
Karzai Posts: 5
edited November 2009 in Speakers
I am just wondering about what are the benefits of a down-firing subwoofer and a front firing one.
How about top firing subs? are there such?
Post edited by Karzai on
  • Krazyz1
    Krazyz1 Posts: 256
    edited October 2009
    I recently bought a pair of Polk DSW 400 PRO. They come configured for down ward firing , but you can buy optional grills to convert them to fire forward. If you plan on this conversion you will need 90 degree power cord and SHORT 90 degree RCA adapter cause all controls will be very close to floor. To the best of my knoledge rule of thumb down for H.T. . Forward for 2 channel. I am running 2 channel down. Forward would be to much I think. Down is working perfect. I talked to 2 different techs at polk running same sub down on 2 channel. Go to a web site www.audioadvisor.com They have a Abyss 300w 12" sub on sale for699.99 ( Manufactured by Martin Logan ) It is unique by the way you put the sub in it's "cradle",you have 4 options on firing angle.Forward , down and 2 different angles between forward and down. If it makes you feel any better reg. price is 1,099.00
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Never saw a top firing sub.
    As for down and front I don't know if there is a really big difference. I never had a down firing sub.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • classic carl
    classic carl Posts: 662
    edited October 2009
    My 2 channel sub has both a front firing and a down firing 10" driver in it. It does the job more than adequately. I have the xover set to 40 hz. My Monitor Audio Silver RS8 towers go down to 33 hz on their own. The sub adds just enough low end help without being boomy.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • everpress
    everpress Posts: 862
    edited October 2009
    Read on a few forums quickly that the difference is mostly cosmetic. The only only sonic difference is the mid bass produced from subs is generated from the cone, and a majority of the deep bass escapes the box through the ports, if it is a ported sub. So there are those that swear that they can hear this directional difference, though there are no tests to show that the sound is actually radiated any differently.
    If you have kids or a pet, go for down firing... If you like the look of the front firing, go for that, is basically what I read.
    ? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
    ? Polk RTA 11TL's (FR and FL)
    ? Polk TSi200's (RR and RL)
    ? Polk CS10 (Center)
    ? Polk PSW-350
    ? Grado SR-60i Headphones
    ? Fii0 E5 headphone amp
    ? iPod touch (8 gig)
    ? iPod Classic (80 gig)
    ? Mac Mini (as media server)
    ? xbox 360
  • Face
    Face Posts: 14,340
    edited October 2009
    Recently, there appears to be a trend towards front firing opposed to down firing.
  • Motzart
    Motzart Posts: 1,075
    edited October 2009
    Personally I like the down firing but it depends on a few factors.....
    Is the bottom open and speaker firing directly on the floor?
    Is the floor it's firing into carpet or hard wood?
    (Firing into carpet is no good!)
    Does the down firing sub fire into a open wood bottom?
    Not a lotta down firing ones anymore from what I have seen.
    My Velo front fire really does it's job tho!!
    Then there is the ported verses non ported debate......
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • obieone
    obieone Posts: 5,077
    edited October 2009
    I don't know the science behind this subject, and this is JMO, but, Down= HT, Front= Music.
  • max mike
    max mike Posts: 8
    edited October 2009
    There is a big difference if you have pets or small kids. If you have either down firing may save you some serious grief.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    obieone wrote: »
    My front firing HSU-project sub rocks everything here for HT. Bluray content under 20hz is definitely felt from this thing. :cool:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Karzai
    Karzai Posts: 5
    edited October 2009
    thanks for all the input guys.
    the answer that has made more sense to me is that the orientation has something to do with music or home theater sound options.
    I have a carpeted floor and from what motzart said, why did polk not advise on this? they are even encouraging the use of down firing sub on carpeted floors (look at those spikes for carpets).
    any thoughts on these?
  • chrisfromalbany
    chrisfromalbany Posts: 41
    edited October 2009
    I think something is being missed... I thought downfiring took more abuse on the woofer due to having to fight gravity when firing the woofer. Side wont have this issue.
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2009
    Karzai wrote: »
    My PSW1000 is sideways firing, with a woofer on either side. If I wanted to I could knock the house down by turning it up, but I'm not a basshole. :rolleyes:
    treitz3 Posts: 20,121
    Face wrote: »
    I don't know about any trends Face but I can attest to this with my audio travels. When using certain down firing subs on a suspended wood floor or second story [with or without carpet], there is a delay that becomes rather annoying. It's almost like the vibration and part of the sound wave reaches the listening position a 1/4 a beat too late. Just imagine getting a powerful drum beat, followed a split second later by another half **** drum beat that was supposed to be only one tight beat. I have yet to experience this with a front firing sub to date.
    Other than that, the "punch" of a front firing sub seems to envelope you more into the music [more accurate a reproduction IMO] and not just provide the room with widespread bass or sometimes "boom".
