Just a comment and a question..
royalty
So I own an onkyo tx-sr706 and I would just like to point out that often with many songs I find this receiver to be a bit bright, especially with my rti10s. However, I also found it to be a bit bright with some monitor 50s too. One thing I did notice was that when I switch the onkyo to pure audio mode; a lot, but not all of that brightness seems to go away.....
While still not an awesome sounding for a pre it does improve the sound a bit this way. So my question is: what is causing this brightness? Is there something in the internal electronics that pushes some brightness or harmonic distortion on these that can also be turned off when pure audio is on? If so, then why would onkyo design something that imparted so much noise or baggage to signal?
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Post edited by royalty on
Some high end tilt is good for home theater. If you want warmth, pick up a HK."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Is it possible that Audyssey has you set up a little bright? Try turning it off (you are effectively bypassing it in "direct") and see if things improve.
I have a 606 and I think it is pretty good really, but I did not like it with my Monitor 50's at all. I ended up with some older LS 90's. It sounds fine with them.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
