Wireless Router buying
bassaholic
I've been reading router reviews and still cannot figure out which 1 to buy. I just bought a PS3 and want to stream movies/ music from my desktop. Price is not too much of an issue. Reliability and speed are. Thanks, Steve
Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
RTiA9-fronts
CSiA6-center
RT55i-surrounds
Post edited by bassaholic on
Just got a wireless router about 6 months ago to replace my crappy Linksys, it's a D-Link Xtreme N Wireless-N Gigabit Router. I have had 2 PS3's, an XBox 360, Itouch and a laptop all pulling a signal off of it at once and it kept right on chuggin. Haven't had a problem with it locking up or dropping a signal even with everything on at once. May not be the best option out there, but has worked very well for me. 4.3 out of 5 stars from 119 reviews at BB. Link below.
-Jeff
http://www.bestbuy.com/site/olspage.jsp?skuId=8040121&type=product&id=1157068454881HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
If you want to stream HD, you'd better run some cat5 or 6. Otherwise, I've had pretty good luck with Netgear and PS3 Media server. Make sure it has QOS.
http://www.staples.com/Netgear-HD-Gaming-5-GHZ-Wireless-N-Networking-Kit/product_754679?cmArea=SEARCH -
Linksys WRT54G2 Wireless-G Broadband Router
I have always used Linksys, and they have never failed me. I just bought the above unit 2 months ago and it's been flawless. I use it in conjunction with this modem:
Linksys CM100 Cable Modem with USB and Ethernet Connections -
Linksys almost any of them are going to be fast and reliable.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
D-LinkSpeakers: SDA-1C (most all the goodies)
Another vote for Dlink, my whole house is run with Dlink stuff: two wireless N routers, and a switch.Shoot the jumper.....................BALLIN.............!!!!!
Another vote for the Linksys WRT54G2 Wireless-G Broadband Router. I've had issues with D-Link's in the past (can't connect to certain people no matter which ports you open up).
Never had an issue with the Linksys. Now I'm stuck with a crappy Actiontec that's been manhandled by Verizon's software. -
Netgear, D-Link, Linksys will all do the job for vanilla wireless G.
Just make sure you use WPA2 encryption and use a 504 bit key. If you plan on streaming any HD (like the other poster said) you would optimally want to string some CAT5 cable. If you can't then go with an N wireless router and N cards. -
I tried streaming to my PS3 over my Apple Airport Extreme (Gigabit with draft n) and latency was annoying (e.g. when changing tracks).
Don't know about other wireless routers, but I think I agree with above who recommend hard wired system.
When tested with Windows Home Server, speeds and latency were better, but still rather slow. Connecting hard drive to Apple Airport Extreme and trying to stream media that was was much slower.
You could also try some powerline ethernet adapters (I stream to a Slingcatcher using some rather generic Netgear XE102 refurbs I got off of ebay and it works well; but it is rather hit or miss depending upon how your electrical wiring in house is). I bet Slinglink Turbos would probably have better performance, though it is still ymmv. -
mshan242700 wrote: »I tried streaming to my PS3 over my Apple Airport Extreme (Gigabit with draft n) and latency was annoying (e.g. when changing tracks).
Hmmm... I have an HTPC with wireless and the music streams fine. I can also stream a DVD with no problem. Just watched Abyss. -
Agreed with hard wiring your system if at all possible. If you plan on steaming movies/videos then you will be better off that way. I can be full bore uploading and still stream fine while hard wired. But trying that with the wireless is almost impossible. -
I have an Apple Airport extreme. I play a game, Aces High, on it all the time. High resolution graphics and multiple players, never have a problem. And I'm talking hundreds of people on at the same time...
just ask demiurge how many colorful 4 letter words i've been using due to my crap linksys wireless setup when we play xbox live. but i am utilizing 3-4 wireless g sytems at any given time plus 2 computers hardwired to the wireless router. so, YMMV.
as i told him, if i'm up to the task this coming winter when it's not 238 degrees F up in the attic, i'll try to run some hard-wire.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Yeah, Linksys has gone to hell since Cisco acquired them. The UPnP doesn't work correctly, especially with Xbox Live, meaning you have to do port forwarding and give your 360 a static IP if you ever want to straighten out the NAT problems. Not too difficult to do, but still a pain in the ****.
I personally don't trust D-Link products, since everyone I know who has had one has had it die a fairly quick death. I got one to use as an access point for a conference room at my office and it died 2 weeks after purchase. YMMV.
So far, the most solid, reliable, and easy to set up router that I've used is the Netgear Wireless-N router that I'm using right now. I haven't had a single problem with it, it handles Xbox Live without any port forwarding, and has generally just been a joy to use. It also gets solid signal clear to the other end of my house, which my Linksys couldn't do even with DD-WRT, high gain antennas and boosted signal levels.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
i'm keeping an eye on this here thread. my linksys with ddwkrp in cinncinnati or what not just ain't gettin' it.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
I use all Lynksys Products and have never had an issue. For the most part routers and modems are just switches. Very Basic switches that have a bunch of hype to make people by theirs. Dont fall for the hype. However the user software that these products use and the support makes a big diff. Lynksys has always been good to me.
Netgear for all windows systems, Airport for everything Apple.
NuffsaidReceiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference -
I'm currently running all WRT54G's with DD-WRT. They are all rev4 or lower so they have more ram. One is a GS, which has double the original ram. I run them in bridge mode and mesh the house with signal. It's awesome, and rarely is there a problem unless the main one loses power. No lockups, no problems. Speed could be better, 54G is getting long in the tooth. Maybe I'll upgrade to N, but I'd rather hardwire and leave wireless for surfing only.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
D-Link for the past 7 years, here. I don't personally have anything bad to say about Linksys, though. I've set them up with no problems as well. D-Link used to be cheaper, which is why i initially went with them, but that gap seems to have closed some.
I'll be shopping for a new router here shortly, and it'll be D-link again.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »D-Link for the past 7 years, here. I don't personally have anything bad to say about Linksys, though. I've set them up with no problems as well. D-Link used to be cheaper, which is why i initially went with them, but that gap seems to have closed some.
+1 I stand behind my D-Link recommendation, hands down the best router I have ever owned. I have owned most brands and the D-Link has given me the best results by far.
-JeffHT Rig
Blu-Ray- 80 GB PS3
TouchyFeely wrote: »I use all Lynksys Products and have never had an issue. For the most part routers and modems are just switches. Very Basic switches that have a bunch of hype to make people by theirs. Dont fall for the hype. However the user software that these products use and the support makes a big diff. Lynksys has always been good to me.
I'd worry about using those offbrand products. Maybe give Linksys a go instead?Main Surround -
I have two Linksys rounters (54GS and WRT2) both works fine. 54GS bought in 2005, still going strong (knock on wood), WRT2 bought this year, courtesy of Newegg special refurb (as new) for $23.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I'm looking for a router that I can use as a bridge in the home theater.
My main wireless router AP is a dual band Linksys (Wireless N). I don't use the 5GHz though because it doesn't go through walls nearly as well as the 2.4 band. That said, I'm happy enough with the Mixed Mode on the 2.4 band, my wireless N laptop shows connection speed from 150-300Mbps.
Any recs? I want something with 4 ports, doesn't need gigabit lan since the devices connected won't be talking to each other. Would like something wireless N using the 2.4 band and I'm ok with using 3rd party firmware, however, if I don't have to that would be great as well. -
Phantom, that's what I do with WRT2. I hacked it to work on bridge mode (instructions are readily available, and pretty straight forward). It is now hooked up to a DirecTV DVR to stream video on demand. Should play nice with your dual band linksys, after all, they are siblings.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
is wrt2 the model #? Is it wireless N?
don't see wrt2 listed here:
http://www.linksysbycisco.com/US/en/products/Routers -
http://www.linksysbycisco.com/US/en/products/WRT54G2
sorry, it's an abbreviation for WRT54G2. Unfortunately it's not a wireless N for your purpose. Are you running mixmode G/N?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Yeah, mixmode G/N. I would use N only however, I also have another WRT54G in bridge mode connected to the alarm system. That said, the mixed mode still gets better results that G.
I have owned a D-link and had nothing but problems, Linksys and Netgear have worked fine for me.
Well we have had our linksys for 4 year with no problems. But just to make me happy I tried a air port out, even vista computer love it better than the linksys. My apple likes it as well. So either linksys or apple airport.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
