How to open the Carver TFM-45
vijayl
Dumb question -
I removed all the screws at the bottom-side and cudn't open that top cover.:o
I also removed the screw at back-top.
BTW - I'm doing this to replace the lamps.
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50
Post edited by vijayl on
Put the screws back into the bottom, and try the screws that are on the side of the amp.
It doesn't have any screws on the side.. and I'm pretty sure (by common sense) these are the right screws that I have removed but there must me one more thing that I need to do to release the lid :-(
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
Storage-RTi8,CSi5,PSW505,Monitor50 -
The front plate frame had to be removed before I remove the top cover.. New lamp needs to be soldered so running to Frys to get Soldering gun and may be sucker
Thanks GG for the idea..
Def Tech Mythos ST
