Comments on this possible setup -
Pycroft
Pycroft Posts: 1,961
edited October 2009 in Electronics
Hi all...
I've been shopping around for a receiver. I found one at a local sale that seems reasonable. Can anyone who has this receiver or something similar comment?
The Receiver is a denon 2807.
I would be hooking up RTA11TL's, CS400, Monitor 30's and a Def. Tech. Prosub 800. I would be using a Panasonic BD35 for Blu Ray - the 2807 does not decode the newest True HD or DTS Master codecs, so I'd be using the BD player. I currently use an Onkyo 606. Would this be a big upgrade by itself? I'm looking at something with Preouts, so I can add some more amplification. How do you find the video on this receiver? How would the system sound with using the BD player to decode the newest codecs?
Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • Pycroft
    edited October 2009
    ...Also looking for general comments about the 2807 - even if you don't have a similar setup.
    Thanks again,
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
