Yes, another stupid question :) AVR's and True HD
Point well taken, my 806 doesn't have the Burr Brown DAC's or maybe I would try it out with a BR player that did Bitstream, since my only option with the PS3 is LPCM.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Sorry if I'm being repetetive. Many have said you don' tknwo the OP's intent...well, I think it may have been lost int he middle somewhere :0 I am looking to upgrade my AVR to something with Preouts and have been looking at a number of models - HK 254, Denon 1910, etc. (Leaning toward the HK because of price). I didn't know that my BD player could decode and use the truehd, dts master codecs even if my avr didn't. My original intent was to find that out, and it seems it can. The next question was, if I go with an AVR with preouts, that does not decode the codecs, and let my BD do it, would I lose any quality. I think you probably answered that in there somewhere, but it's gotten a bit technical for me with DAC's and bitstream, etc. etc. I can get a HK 254 refurbished for that...it has preouts and can decode the codecs. Now, the big question is, can I get a better system with preouts that doesn't decode for the same price or better, and if so, would I be losing any quality using the BD player in that way? If so, I'd love to hear recommendations.
Pycroft2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
Sorry for getting of track on you Pycroft, I am afraid the only way to tell if you will be missing out on anything is to try it, or hope someone in a similar situation as you can offer some insight. Hope you get the answers you are looking for, without us rambling off at the mouth again, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
As I stated earlier, it's gear dependent. :rolleyes:
Your BRP will not always sound better if it internally decoded the signal, neither will your AVR if you chose that to decode it. It's one or the other depending how you have things hooked up and what avr/brp you're using.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Pycroft,
Things have gotten a bit OOH on this thread but it is a good discussion to have really.
My .02:
First, we have exactly the same AVR. There are much better AVR's out there and the price goes up accordingly. I also have a BDP-83 so I have all options available as far as decoding. I can decode in the player and output multi-ch LPCM and I can bitstream and let the Onk decode. I will say this, I prefer that the Onk do the decoding. YMMV
Do not confuse decoding with digital to analog conversion (as I think some have). Decoding the bitstream (soundtrack) that is on the disk, whether done by the player or the AVR is done by a decoder chip NOT a DAC. The -83 has both and so does the AVR (in my case).
I happen to prefer that both decoding and conversion be done in my AVR.
My simple advice is this, unless you can "trade up" on the AVR. Hold onto what you have. Certainly dont step backwards just for pre-outs. I think you will be disappointed.
Fact is we are traveling a similar path my friend. I too bought a nice set of older polks when I became unsatisfied with the way my system performed. It was a good move. I got a very capable set of speakers to build around.
Then I realized that for music listening, my Onk 606 wasn't going to cut it. I was happy with the performance for HT though. In that respect, for me, it was ok. When I first started down this path, I was thinking I did about a 50/50 split between movies and music. Turns out I listen to WAY more music than I do movies. TV is casual listening for me, not critical. So I dont really count that. Evaluate what you are trying to accomplish with regard to your upgrades. Better 2 channel? Better HT? Are you unable to achieve reference levels with DVD/BD and Cable/Sat as sources or are you unhappy with the music reproduction of your system? Is it the speakers or the amp? What are you listening priorities?
I too thought "I need pre-outs so I can add an amp to my front 2 channels to improve my music listening experience."
What I ended up realizing was this: No matter what I do with regards to an AVR, I am not going to achieve my 2 channel goal. AVR pre-amp sections simply are not capable of what I was looking for. Only separates can achieve that for me and I wanted a tube pre-amp and the ability to swap pre-amps and amps . Not an option with an AVR.
For HT, only a pre/pro or AVR has all the capabilities I want and frankly the Onk was totally capable in that respect. It does all the latest tricks and does them well. I too considered upgrading to an AVR with pre-outs so I could throw some power at my front L/R for music listening but I am so glad I didnt. I wound up doing an entirely separate rig for 2 channel. The only inconvenience is swapping speaker wires when I want to listen to the 2 ch. rig. Its not much of one with banana plugs. Takes 10 seconds. Point is, I identified exactly what I wanted to improve and focused my limited resources on that with excellent results.
Upgrade-itis is a ****. Every time you improve one aspect of your system, another aspect seems to fall short. Fact is there is no shortfall that money wont fix.
So dont let suggestions of others dictate your upgrade path and patience is key if you dont have the money to just throw at it. An older AVR may solve one problem (pre-outs) but cause another (No decoding of HD codecs). Why not wait until you can spring for an AVR that has pre-outs AND does the decoding? I know HK is a darling around here but Onkyos are no slouches and the Audyssey stuff is well worth having. I just want you to think about this stuff, there is always an economic compromise to be made in this hobby. Make sure you make the right one.
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
technology moves too damn quickly
seems like my upgrades are already outdated lol -
kuntasensei wrote: »I agree with most of what you said, but the LFE track being boosted 10dB at the decoding stage has nothing to do with "overloading the connections". It's part of the Dolby and DTS specs for their individual bitstreams, primarily to give them additional range in the LFE channel in theaters (so naturally, it carried over that way to the home). That's why "reference level" gives you 105dB potential in the main channels and 115dB in the LFE channel.
I guess the question becomes why would you need to adjust the recorded level and boost it later if there were no bottlenecking in the electronics. It's what I read about the limitations of the connection with the additional LFE range. -
If you have a BRP and you set it to send PCM, then the BRP DAC is decoding the sound and there is not decoding done by the AVR.
Only true if you use analog outs on the player instead of hdmi for the PCM. -
I don't think of it that way.
I think of it as if the BRP has a better Decoder (DAC), then by all means use the BRP and set it to PCM and don't spend so much money on the AVR.
If you think that your AVR has a better DAC, then set your BRP to bitstream the sound, let the AVR decode it using the AVR's DAC and be happy that it says True HD or DTS HD on your AVR.
This said, I belive the PS3 has a very good DAC, so it doesn't surprise me that you chose it instead of your AVR.
Your statement about the ps3 is very unlikely. The ps3 only has stereo analog outs so you can't even listen to a multichannel surround track using the ps3's DAC. To listen to lossless surround with the ps3 you have to send the PCM over hdmi. In this case, the decoding (TrueHD etc. to PCM) and PCM transfer to the AVR is all done digitally. There is no analog conversion (DAC converts the digital to an analog signal). -
Pycroft
Unfortunately, you have to understand how the audio is processed in order to figure out what works best for you. I will try to give you a non-technical answer where I can, but you should try to understand the process to know what trade-offs you are making.
Decoding (uncompressing, unzipping)
There are three lossless formats, uncompressed PCM and TrueHD and DTS-HD Master Audio(MA). All the other alphabet soup out there are lossy formats which simply means that they take an uncompressed PCM master, compress it to make it smaller (like a zip file on a pc) and when the file is uncompressed (decoded), there are parts of it missing that were taken out in the original compression. So a Dolby Digital compression process, for instance, may eliminate certain frequencies that it thinks the listener won't mind losing from the original master.
So for uncompressed PCM (getting rarer as an option these days although Sony and Disney used to use it a lot), there is no 'decoding' necessary in either the AVR or the player. For TrueHD and DTS-HD MA, the player or AVR must 'unzip' the file back into the original PCM (losslessly) to use it. No one has ever listened to a TrueHD or DTS-HD MA track as its compressed form is unusable. It must be uncompressed back into its space hogging PCM form in order for the AVR to process it and send it to the speakers. So people are really listening to the original PCM master with all three formats and this is why all three lossless formats should be equivalent to each other with the quality coming from the original master, not the zip/unzip process. And that is why uncompressing the file (decoding, unzipping whatever you want to call it) is less relevant to sound quality than the digital/analog conversion process. And since you get the same PCM with either a player or AVR decode, it shouldn't matter where the decoding process takes place. Although, as I already noted, the LFE 10db boost is not handled consistently across all AVRs on the PCM input. So if you aren't willing to go through the extra technical effort to make sure your system is calibrated and setup properly for this boost on the PCM input, then you are better off just letting the AVR uncompress (decode, unzip) the lossless track as it always knows to add the boost back in. However, you will still run into trouble with the uncompressed PCM tracks (as these are always transmitted as multichannel PCM).
Digital/Analog Conversion
This is where much of the quality in digital processing comes from. And this really predates any talk of lossless compression/uncompression/blu-ray etc. It comes from the simple fact that although we process audio largely in the digital world these days, speakers are still completely analog components. So as ironic as it may sound, after all the digital voodoo that goes on under the hood of a modern AVR or pre-amp, we end up listening to a purely analog signal sent to the amplifier stage and over the speaker wires to our speakers.
So at some point, the digital 1s and 0s have to be converted back into analog and sent to the amplification stage and out to the speakers. There is no 100% way (lossless) to go from digital to analog and there will always be some guesswork involved. That's why the DAC (digital/analog converter) chips will add their own color to the sound.
When you decode (unzip) lossless formats in the player and use the analog outs to send the results to the AVR or pre-amp, the player is converting the digital information to analog early in the process and using its own internal DAC chips after the decoding (unzipping) process, dumping the results of this conversion to the AVR or pre-amp. This is the only situation where the DAC chips of the player are relevant.
When you use the player to decode (unzip) and send multichannel PCM over HDMI OR decode (unzip) the bitstream on the AVR side, it is all digital. So the AVR must use its own DAC chips to convert the digital information before sending an analog signal to the amplification stage and on to the speakers.
Short Answer
If you don't want to worry about if the AVR is applying the 10db LFE boost properly to the PCM input, then use bitstreaming and decode (unzip) in the AVR. But you will still have to worry about the LFE boost when listening to the uncompressed PCM track on some blu-rays. And it is entirely possible to get great lossless audio letting the player decode (unzip) lossless tracks and sending the result over either hdmi or analog outs to the AVR with no discernable loss in audio quality.
If using the analog outs of the player, all the old arguments about player vs. AVR DAC quality still apply since you will be using the player DACs to do the initial digital to analog conversion instead of the AVR's. -
This statement does not sound right to me so I am going to re-write it. - sorry if I am misunderstanding it. I am surprise no one else has said anything.
If you set the BRP to send bitstream, then the BRP will not decode the sound and the decoding will be done by the AVR.
No, you have it wrong. See another post by cheddar for an excellent explanation. DAC means digital to analog and PCM is digital, hence the BRP DAC is not used. The AVR's DAC is used.
Also, I do not have the low bass problem since I do not use the LFE output for the sub. All my speakers are set to large and I drive the sub off the front channel pre-amp outputs. Instead, of low bass I get a much better integrated bass with the lossless audio, instead of booming bass with lossy audio as on a DVD.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
The +10dB boost is actually a holdover from 70mm magnetic film where mixers had limited headroom on the analog tracks. It was a limitation of that medium. The +10dB boost was carried over to digital because mixers were already accustomed to mixing LFE at -10dB.
Here's some good reading on the subject.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »The +10dB boost is actually a holdover from 70mm magnetic film where mixers had limited headroom on the analog tracks. It was a limitation of that medium. The +10dB boost was carried over to digital because mixers were already accustomed to mixing LFE at -10dB.
Actually, the article specifically mentions the limitations of the ICs. It's more than a legacy hold over from analog.Interconnects
One important point is that the 10dB boost to the LFE is performed at the final amplification stage. The potential extra volume of the LFE channel could not pass through interconnects, analogue recordings or digital recordings without going over the specified limits by a factor of 3. -
I stand corrected. I meant the decoded chip instead of digital to analog(DAC) chip.
sorry.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
Actually, the article specifically mentions the limitations of the ICs. It's more than a legacy hold over from analog.Both blu-ray and standard dvds have their LFE tracks recorded at -10db to prevent overloading the connections between the player and AVR.
I wasn't saying that the limitations of the ICs wasn't an existing issue... Just saying that your original statement that Blu-ray and DVD have the LFE track recorded at -10dB to prevent overloading the connections is not correct. They have the LFE channel recorded at -10dB because the original theatrical mix has the LFE channel recorded at that level, which is a holdover from analog multichannel on film that carried over to the digital formats. The specs exist to suit the format, not vice-versa.
But I digress. Your original point remains.Equipment list:
Emotiva XPA-3 amp
kuntasensei wrote: »I wasn't saying that the limitations of the ICs wasn't an existing issue... Just saying that your original statement that Blu-ray and DVD have the LFE track recorded at -10dB to prevent overloading the connections is not correct. They have the LFE channel recorded at -10dB because the original theatrical mix has the LFE channel recorded at that level, which is a holdover from analog multichannel on film that carried over to the digital formats. The specs exist to suit the format, not vice-versa.
If you want to point out the historical significance of the original recording methods, fine. The fact remains that they have no choice but to record the LFE at -10db. Even if they wanted to change the standard for blu-ray, they couldn't unless they forced an upgrade to a new hardware standard (and bandwidth is always at a premium anyways, so it may just be the case that it's more economical to keep the status quo for the .1 surround channel that filters out the higher noise levels caused by the boost anyways) because as the article clearly states, 3x the available bandwidth would overload the rated specs of the existing connections, which is what I stated. I made no reference to the historical root cause of the problem. Only the current hardware limitations which would prevent full strength LFE channels from being transmitted. For my statement to be incorrect, the studios would have to have a choice to record at the higher level without overloading the current connections and simply choose not to do it because they are used to the old routines. And studios remix sound for blu-rays all the time. Certainly, the 7.1 lossless tracks of the classic Star Trek TV blu-rays never existed before the blu-rays were produced. Even these new lossless tracks can only have a -10db LFE track because the hardware would be overloaded by a 3x higher level signal. Which is basically what I said in my initial statement. -
In order to do any meaningful comparison of dynamics between tracks, you must first ensure that the equipment is callibrated properly. Not sure what you mean by a 'known LFE bug," but any comparison between tracks with proper LFE and with weak LFE will show exactly the lack of 'shake my room to pieces' that you describe. And it should also color the perception you have of other dynamics as well because the upper end without the bass to balance it will sound very thin compared to a properly callibrated situation.
Using PCM over HDMI, the culprit is usually not the player but the AVR for a severe drop in bass LFE output. Both blu-ray and standard dvds have their LFE tracks recorded at -10db to prevent overloading the connections between the player and AVR. When an AVR decodes a bitstream of either lossless or standard audio codecs, since it knows it's TrueHD, or Dolby Digital, or whatever because it decodes it, the AVR also knows to apply a 10db boost to the LFE channel before it is output to the speakers.
However, if the player decodes the signal and sends it out as multichannel PCM, the AVR has no idea if the PCM was originally TrueHD, Dolby Digital, or even audio from an SACD. So some AVRs apply a 10db boost to the LFE and some do not. So if you callibrated your AVR properly, then feed it multichannel PCM decoded from the player and the AVR does not automatically apply a boost, the bass will be 10db too soft. That is a significant reduction in the low end of the track and will have the EXACT symptoms you describe from your listening experience. You should manually set your AVR to boost the LFE channel +10db on multichannel PCM and see if this helps your situation. There really shouldn't be any other reason that a bitstreamed DD track should sound better than a player decoded TrueHD track if everything is setup and callibrated properly. In fact, this is the exact thing to look for that should tell you that your AVR is not adding the +10db LFE boost to the player decoded PCM. Since the TrueHD track is lossless, there shouldn't be any difference in the PCM that comes from the player decoding vs. bitstreamed decoding (hence the name lossless). DACs, on the hand, do a lossy conversion from digital to analog which does add its own 'color' to the sound. But as has already been mentioned, the DACs used in both player (over HDMI) and AVR decoding should be in the AVR.
In my particular case, my Panasonic Blu-ray deck has been plagued by a known "LFE bug" which means the PLAYER does not send out the correct amount of bass information over HDMI when the PLAYER is doing the internal decoding to PCM. It's a known problem with the first-generation Panasonic BD players, specifically my DMP-BD10A. You can look it up if you like; from everything I have learned, it's not an issue of the AVR not applying the +10dB or so of LFE information, but the player missing about 5dBs or so of LFE over HDMI when internal PCM decoding is taking place. -
wutadumsn23 wrote: »Hey guys, saw this thread and figured I'd offer my $.02. I am currently running a PS3 as my BR player and I send my HD signal via HDMI LPCM to my AVR and I am extremely happy with the results. If I am missing anything by not sending the signal analog or Bitstream, I don't want to know and don't see how much better it could sound. Don't have any plans to "upgrade" to a dedicated BR player just so I can see Dolby TrueHD or DTS HD Master Audio on my AVR's front panel, lol.
-Jeff
Hey Jeff,
Thanx for your contribution; indeed, it sounds like you are running your system the way I run mine, with internal decoding taking place in the PLAYER not your AVR -- and you are right, the only way those indicators will light (for Master Audio or TrueHD) would be if the signals were bitstreamed...
It's just that many of us are experiencing "unequal" sound quality when going the player-internally-decoding-to-linear PCM-route as compared to bitstreaming -- in MY case, it's probably due to the "LFE bug" which plagues the early Panasonic players when sending PCM over HDMI, but I feel internally decoded tracks on my player simply don't have the same tactile impact as lossy tracks bitstreamed to my Onkyo 605. -
Let's see if we can clear some things up in this thread regarding confusions over DACs and where processing takes place, etc. as easily as possible:
If you set your PLAYER to internally decode TrueHD -- or any codec for that matter -- to multichannel PCM and it's being sent over a DIGITAL HDMI connection (well, the new Dolby and DTS codecs cannot be passed over coax or optical digital, so HDMI or analog is required) then the AVR or PROCESSOR'S DACs are being utilized for final output.
If you set your PLAYER to internally decode these soundtracks into multichannel PCM and you're sending them over ANALOG, then your PLAYER is utilizing its internal DACs and processing, sending the final output to your processor or AVR for playback.
If you set your PLAYER to BITSTREAM the codecs, the signal is sent direct to the AVR or processor, where everything is handled by said processor/AVR.
Does this look right, finally? :eek: -
Mike LoManaco wrote: »Have you read anything about the ongoing rage and debate regarding the fact that soundtracks shouldn't sound ANY different based on where they're decoded, in a player or in a surround device, such as a processor or AVR? These people SWEAR by this notion -- but my ears are telling me that something is indeed different when the TrueHD tracks are being decoded by the player rather than the receiver because they don't sound nearly as dramatic in output.Mike LoManaco wrote: »In my particular case, my Panasonic Blu-ray deck has been plagued by a known "LFE bug" which means the PLAYER does not send out the correct amount of bass information over HDMI when the PLAYER is doing the internal decoding to PCM. It's a known problem with the first-generation Panasonic BD players, specifically my DMP-BD10A.
Then maybe try not to weigh into a debate with broad generalized statements when you wouldn't expect to hear equal audio (player vs. AVR decoding) since your equipment is malfunctioning and you've never heard properly processed player decoded lossless audio...just a thought. -
REALLY DUMB subquestion
What would happen if I had the Panasonic DMP-BD35 hooked up to my Denon 3808ci (thru HDMI or other digital) if I only have 5 speakers... would I get the new formats? What would happen with remaining 2 channels.LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
Not called for -- and aside from the LFE issue with the player, I am hearing lossless audio.
You asked about the LFE bug, claiming you were not certain what I meant by that, and I was merely explaining it. -
yes you will.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
TV: Sony KDS60A2020
DBP: Sony DBP-S350
Mike LoManaco wrote: »Let's see if we can clear some things up in this thread regarding confusions over DACs and where processing takes place, etc. as easily as possible:
Correct. -
You only get the new formats over HDMI. There is no 'other digital' as an option for DTS / Dolby HD audio. Just want to make sure that you know TOSLink won't get you DTS/Dolby HD. -
Mike LoManaco wrote: »Not called for -- and aside from the LFE issue with the player, I am hearing lossless audio.
I said you've never heard properly processed player decoded lossless audio. I would think as someone who prides himself on writing audio and video critiques of movies, that you would want to actually hear player decoded lossless produced per proper specs before you suggest generalized conclusions about it being inferior to AVR decoded lossless and even standard dolby digital. If you don't see a problem with generalizing from one faulty player to suggest that player decoded lossless is inferior to AVR decoded audio, then carry on...make any claims you want. But I would recommend that you upgrade your player at some point so that you can eventually write a critique based on properly processed lossless audio whether decoded in the player or AVR. It really is far better than the undynamic, unpunchy sound you often describe and is a joy to listen to. -
First of all, I can see this is going in the direction of "let's piss all over Mike's reviews and his claims once again because we have nothing more to bring up..." so I'm only going to entertain this once more with you, and then I am done with this thread.
What exactly does my preference for the "punchy" attack of lossy DVD tracks over lossless uncompression have to do with the price of milk -- more specifically, what does it have to do with my abilities as a reviewer and what I supposedly "pride myself" on? Next time you wish to begin a flame interruption in a nicely flowing thread, check what comes out of your piehole -- I will say this once more: My player has an LFE issue which cannot send bass in the correct amounts when the deck itself is decoding TrueHD or sending uncompressed PCM over HDMI, but it still decodes the TrueHD correctly[/i]...the magazines and online review sites I contribute to absolutely know and understand this deficiency in my system and give me leadway for it, and I indicate where the LFE was shallow and why it seemed that way on my setup for a particular Dolby TrueHD track.
Your instant attack of me was just that -- an arrogant immediate response of "maybe you shouldn't make generalized statements about this...just a thought..." that was cruel and irrelevant. I AM experiencing TrueHD, it's just handicapped a bit by an LFE problem with my first generation player -- what does have to do with me making generalized statements about all this?
I know the player has an LFE bug, and I was sharing my experiences of this in the thread, but attempting to help the OP. It DOESN'T mean I don't know anything in terms of being able to review a disc for print or discussion. I'm unsubscribing from this thread now, being that my thoughts have been relayed on it -- I hope the OP gets his answers in a coherent fashion. -
You have to admit, Mike... Cheddar has a valid point, and you know that you need to get a new player.
On a related note, I wonder if we can have the admins change the unsubscribe option to read "take my toys and go home". Seems to be what some people use it for.Equipment list:
Emotiva XPA-3 amp
Mike LoManaco wrote: »I know the player has an LFE bug, and I was sharing my experiences of this in the thread, but attempting to help the OP. It DOESN'T mean I don't know anything in terms of being able to review a disc for print or discussion. I'm unsubscribing from this thread now, being that my thoughts have been relayed on it -- I hope the OP gets his answers in a coherent fashion.
I never said anything one way or the other about the quality of your reviews other than to point out that with an admitted -5db problem on the LFE and what I think might be a -10db problem if you haven't configured your system properly to boost the LFE PCM by the required amount, you will get the exact results you complain about, a lack of punch and dynamics on player decoded tracks vs. AVR decoded. And that any general conclusions you draw from your faulty player about lossless audio would be premature at best.
In direct reference to this thread, since the OP does not own your faulty player, the multiple posts that you've given which suggest to him that in general, player decoded lossless is inferior to AVR decoded lossless (both of which you seem to have not heard properly processed, just the lossy bitstreamed tracks), brings confusion to the discussion when you haven't even proven that his player suffers from the same LFE bug. Those of us who have actually heard player decoded lossless without your LFE bug might know a little better about how it can sound than someone who hasn't. That's all I am saying. No more no less.
