New speaker sets
tinnguyen99
tinnguyen99 Posts: 3
edited September 2003 in Speakers
Hi all,
I just bought new front floor-standing speakers RTi100, and I plan to move R30 to surround speakers, and use with center speaker CS245i, subwoofer PSW250. Are they a good match ?
Tin
Post edited by tinnguyen99 on
  • ohskigod
    ohskigod Posts: 6,505
    might want to upgrade the center. seems like it may be on the small side for your set up. but if it sounds good, then run with it.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • organ
    organ Posts: 4,969
    That set up should work just fine. However, your mains and center are not matched. The RTi100 have silk tweets and the CS245i have tri-lam tweets. If you want a matching front soundstage, check the store ASAP. The new RTi line is coming out and the stores are clearing out the current RTi, CSi production. You should be able to find a CSi30 or the CSi40 cheap.
    Maurice
