Spiking a Subwoofer
michaeljhsda2
michaeljhsda2 Posts: 2,201
edited September 2009 in Electronics
Spiking SDA's has proven to be very effective at improving bass response but has anyone spiked a powered subwoofer on a carpeted concrete floor? I'm gonna try it and see if there is an improvement....results to follow.
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
  • kawizx9r
    kawizx9r Posts: 5,150
    Never tried it or heard one spiked but I don't see why not. I'm building my own sub, and went on a search for random pics of DIY subwoofers and I noticed that there were close to 0 subs spiked.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • TNRabbit
    TNRabbit Posts: 2,168
    I'd be VERY careful using spikes on a sub. Depending on their weight & excursion, they could dig pretty significant holes into your subfloor~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • michaeljhsda2
    TNRabbit wrote: »
    The subfloor is concrete :D
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thuffman03
    thuffman03 Posts: 1,325
    Not sure if that would help or not but you won't know until you try it.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Systems
    Systems Posts: 14,873
    I just got some spikes for my sub. As soon as I find a 9mm drill bit I am going to set it up. Since the carpet is pretty close to the bottom port, I can't help but think that a little more space will result in better sound. I'll let you know.
    Testing
    Testing
    Testing
  • apphd
    apphd Posts: 1,514
    My eD sub came with screw in spikes, also some small discs to place between the spike tip and floor if desired.
  • megasat16
    megasat16 Posts: 3,521
    Raising the sub from the (carpet / concrete / wood) floor will improve bass response from the sub. It has been tried and proven that if you raise the sub at least 6"-12", you can hear better mid-bass even though the lower bass is non-directional.
    Auralex Subdude is probably the easiest way to uncouple the sub from the floor.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • michaeljhsda2
    I spiked them and the bass response is much better, no doubt about it.
    SDA SRS 2.3TL's
    SDA 2B TL's
