Wood cones?
This seems like an interesting idea...
Have no idea how it would sound though. And wouldn't it rot?
http://cgi.ebay.com/MW-Audio-6-5-REAL-WOOD-CONE-Hi-Fi-Woofer-NEW-SPEAKER_W0QQitemZ160311090599QQcategoryZ3276QQcmdZViewItemQQ_trksidZp3907.m263QQ_trkparmsZalgo%3DSIC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D12%26po%3DLVI%26ps%3D54
Main Surround -
Post edited by nguyendot on
No frequency response plots, no thanks."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
JVC quite recently had some small extended-range wood cone drivers.
http://www.jvc.com/Presentations/WoodConeSpeakers/index.html
Think about it: what you want for a speaker cone material is something strong and light that can be made to move like a piston (i.e., rigid) without exhorbitant breakup. Paper is actually dang hard to beat IMNSHO; wood might be interesting but I have no ears-on experience. Some of the modern materials used in speaker cones get everything right but the breakup issue at higher frequencies and thus require complicated/exotic (expensive and inefficient) crossover networks to be successfully integrated into high-performance loudspeakers.
I am very old-school when it comes to speaker design -- I like to see designers work with the properties of a driver, rather than have to work against them :-P
End of diatribe :-) -
I've only read about wood cones in headphones. I've never experienced them; I've not got that kind of money. But, from what I've read, people swear by them. I know that people sometimes buy the lower-end of Grado headphones and make custom wood cups for the ears (to resemble the high-end ones) and spend a pretty penny on them because they say the wooden cups really make a difference. If the material of surrounding area that the sound is enclosed in can make such a large difference, I can't imagine why the cone itself wouldn't make a difference.
I would, given the opportunity, love to audition a speaker set with wooden cones.
? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
? Polk RTA 11TL's (FR and FL)
? Polk TSi200's (RR and RL)
? Polk CS10 (Center)
? Polk PSW-350
? Grado SR-60i Headphones
? Fii0 E5 headphone amp
? iPod touch (8 gig)
? iPod Classic (80 gig)
? Mac Mini (as media server)
? xbox 360 -
Interesting; they also have this Peerless replacement:
http://cgi.ebay.com/Peerless-Copy-8-ohm-Tweeter-Replacement-for-Polk-ADS_W0QQitemZ150364380186QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item23026a5c1a&_trksid=p4634.c0.m14.l1262_________________________________________________
Interesting... I wonder of you clean them with pledge or endustThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
It looks really cool, but I don't know. Seems like it would be flawed due to the make up of the wood cone, since it would be impossible for it have uniform properties across the cone, unless maybe it's laminated or something?? If it were some sort of uniform wood fiber cone as opposed to the veneer looking wood cone, then it may work
What the hell do I know though:D Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
No but Thanks! I only accept Bamboo cone woofers.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
How about that frequency response...30hz to 6kz...Maybe replace 16 mids in the big guys...NO?
I did read where the Bamboo ones WERE pretty impressive...Like mhardy said earlier.
It was JVC's little stereo I read about..and it got great reviews!:D
Great link to that series posted earlier...
I keep looking for some of those little high quality systems at the Good Wills..:rolleyes:Most people just listen to music and watch movies. I EXPERIENCE them.
I like the wool cone Silver Flute drivers for SDA's. They were recommend by a very reliable source at Polk. As for the wood. I took a look at the JVC models, and it appears they used a sheet of laminate to create them. The problem is the grain is only one direction. Not good.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
No off axis response, no thanks.
How about a paper cone with a wood phase plug?
http://madisound.com/catalog/product_info.php?manufacturers_id=177&products_id=8536
I agree with Ben about Silver Flute drivers, they sound great for the price."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Regardless of how they sound, you have to admit they look very cool....
I just ordered a pair of the 6.5" wood cone woofers from Midwest Speaker (as far as I know they are the only place selling these in the US). Not only do they look cool, they sound cool. I listen to a lot of jazz and classical music and Midwest is right about the clarity of the instruments. They included a box design and spec sheet with all the parameters and the frequency graph. I would definitely recommend these. It does not have the standard screw hole mounting, instead of 4 or 8 hole it uses 6 screws. I just had to tap in new screw holes.
If it's laminate, that means by definition there must be more than 1 sheet of wood. That implies that they crossgrained them, therefore not a problem. I'd think mixing layers of wood with layers of polycarbonates or resins might really turn out something wild.
I know there's 1 Japanese maker who are pretty well regarded for their wood speaker cones, I'm sure I read a thread in AK about them.Maybe i can get African Padauk Cones made up!
Highly doubtful. Padauk is one of the most splintery, rigid woods I ever played with. I'd think something that steam bends well like ash or willow is the way to go. You could just stain it red. -
