Capacitor Health
skrol
skrol Posts: 3,452
edited September 2009 in Vintage Speakers
I have heard many of you speak of electrolytic capacitors drying out with age. It sounds like they are good for about 20 years. I was wondering what are the symptoms of over aged capacitors? Which way does the value change? Do they tend to short or open? Sonically, what are the symptoms?
The reason I ask is that, as some of you have read in another thread, I recently started using my vintage 1983 Monitor 5A's. The more I listen, they just don't sound right. All the drivers are functioning but they just don't seem very open and kind of like listening to radio. The speakers are all original and could likely use an XO rebuild by now.
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
    treitz3 Posts: 20,008
    [Sonically] Crackle in the sound, abnormal push, [Physically] bulging and leakage are the typical culprits. Listen and observe. If in doubt? Replace or upgrade.
  • Face
    Face Posts: 14,340
    Yes, values do drift after some time.
  • skrol
    skrol Posts: 3,452
    I found my answer regarding the Monitor 5A's. Speaker stands. I took them off the book shelves and placed then on the stands and it makes a world of difference.
    I did measure the capacitors in one of the XO's and they are still just within spec. The resistors are iffy though.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • McLoki
    McLoki Posts: 5,231
    Main thing to me is not that the caps drift in value over time - it's more that even a moderately priced cap will sound significantly better than what came stock in your speakers.
    It is such a safe, low-cost and relatively easy upgrade, it's almost foolish not to. Definately some great bang for the buck.
    Michael
