Klipsch C-3 with Polk LSi? Looking for a cheaper alternative to the LSiC
jack_mcdowell
jack_mcdowell Posts: 2
edited October 2009 in Speakers
Hello, I have a pair of LSI 25 as my front speakers and LSI 9s as my surround back speakers, as well as 2 RTI8 for the side surrounds. Now I need to get a center channel speaker and I was considering going for a Klipsch since I can't find the LSiC for under $550 at the moment. Does anyone have any suggestions as to how this may sound? Or of any other speaker which might go well with my setup?
Post edited by jack_mcdowell on
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited September 2009
    Have you checked out audiogon? There was one listed for 360 i think just the other day.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • leroyjr1
    leroyjr1 Posts: 8,785
    Don't buy Klipsch. The LSI C's pop up from time to time. Call Polk they should be able to help you.
    http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Daps&field-keywords=polk+lsic&x=12&y=30
    nooshinjohn Posts: 26,000
    you can get an LSIc from Polk Direct for less I believe... Call them on Monday
  • dorokusai
    dorokusai Posts: 25,576
    The Klipsch will sound way too forward and not match very well at all.
    There's a LSiC for $450 @ Amazon.
  • jack_mcdowell
    Thanks for the tips. I didn't know I could call polk direct and get one from them, I actually got my LSi's from their ebay store at quite a bargain so if they can get me a refurbished one then that would be great. And thanks for the audiogone tip, I've never used that site but there do seem to be some decent prices.
  • McLoki
    McLoki Posts: 5,231
    Just wait for a used one. They pop up from time to time and are usually around $300-$350 or so.
    Until then, just run with a phantom center. (i.e. - set center to "none" in your pre/pro.)
    Michael
  • gtu2004
    gtu2004 Posts: 620
    check videogon and craigslist as well. I've seen it go for $200 but I just didn't have a need for it. Besides, I do not think it's a great center at all from my experience of owning it. I think the Csi5 might be equal or even better. But then if timbre matching is your thing then you'd have no choice.
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • Sherardp
    Sherardp Posts: 8,038
    As mentioned above, one on Audiogon now for low price.
  • danz1906
    danz1906 Posts: 5,144
    dorokusai wrote: »
    Agreed,the Klipsch wont match at all!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • j.k.livin
    j.k.livin Posts: 7
    edited October 2009
    I have one I can sell you for 360. I like the overall sound with the phantom center. It is in great shape, no scratches or chips. It sits on a micro-fiber cloth.
