I finally found an affordable balanced power transformer
fbm211
I came across this while checking out the IEGO power cords and plan on getting one in the near furture.Of course Ill have to go with the upgraded silver IEC socket and the IEC isnt just silver plated,,its solid .(99.99)
Anyway at 330.00 (420.00 upgraded) its not cheap but it is balanced and that alone makes it reasonable...The only drawback is that I wont be able to plug the 565s into it and it only has 2 outlets anyway.Im sure it can handle all my other gear though.Preamp,transport,DAC,TT,and TV.
So has any of you seen this yet or have one??
Link>>http://www.acoustic-fun.com/catalog/product_info.php?cPath=23&products_id=34
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Thanks sal.Did those panamax units drop in price.Didnt they run about a grand a few months ago??SDA-2BTL with custom IC
