Marantz or Onkyo??
  • Dawgfish
    Dawgfish Posts: 2,554
    edited September 2009
    ls7z06 wrote: »
    I am real happy with my Onk 806 but I am only running RTi series speakers.. I know a lot of guys bash them but I have been pleased with mine. To get 130w per channel with a Denon or ? it would have cost me 2 to 3 times as much.
    Be careful with getting caught up in the wattage numbers game with AVRs. Like wutadumsn23 said, AVRs rarely put out the watts in real life that the specs say they do. Additionally you have to double the wattage of an amplifier to get a 3 decibel increase in sound level. I also own an Onkyo 806 rated at 130 wpc as well as the Denon 2809CI rated at 115 wpc. The Denon pushed my speakers equally well as the Onkyo (and this was pushing RTI 12s as fronts, RTI-10s as sorrounds, and RTI-8s as rear sorrounds). There was no discernable difference between the two as far as loudness and headroom goes, and in fact the Denon pushed the speakers much cleaner, with less distortion and ran cooler to boot. Some of the Harmon Kardon AVRs out there have much less published wattage specs as most of their counterparts, yet perform just as well if not better than many of their competitors from an amplifier standpoint. They are actually publishing specs that were actually measured in real world, all 7 channels being driven listening condiitons.
    This may sound crazy, but not all watts are created equal! The fact is neither reciever being used alone to push the speakers can hold a candle to my current set-up with all external amplification. Most recievers out there do not have the headroom, reserve power, and sheer muscle of a seperate amplifier (with the exceptions being some of the high end Adcom, NAD, Rotel, etc. and the Pioneer Elites with the ICE amps). Think about this, according to Onkyo, the 806 is rated at 130 wpc x 7. If this were true, this would work out to a total of 910 watts. The 806 weighs about 36 pounds. My Adcom GFA-555 is rated at 200 wpc X 2 for a total of 400 watts and weighs over 40 lbs. So an amplifier puts out a total of 400 watts and weighs more than a reciever that supposedly puts out 910 watts, but yet the reciever has a ton of other processers and circuitry that the amplifier does not have. Why is this? The answer is the amplifier sections of most recievers built today are far less robust, have inferior components, and are much lighter duty than a typical quality external amplifier.
    For the record I'm not writing this to bash the 806 or any other reciever out there. The 806 is a solid reciever, especially considering some of the deals on it out ther right now. I am just trying to point out that it's really fruitless to chose one AVR out there over another purely on a watts per channel basis and that adding external amplification is the way to go to get the most out of your system. Chose an AVR on features, overall sound, and all other things being fairly equal, what kind of deal you can get.
  • Pycroft
    Pycroft Posts: 1,961
    I don't want to hijack this thread, but would love to ask a clarification question...Dawgfish, you say that not all watts are 'real watts'. I am lookign up upgrade my AVR. I have an Onkyo 606 - 90 Watts per channel (Or so they say :). I don' thave the money to spend 600 + dollars on an AVR, but can build something a piece at a time. Someone suggested HK AVR 254 - 50 Watts per channel with Pre-outs and reasonable price. I asked about the 50 watts, and that this was worse cause I have a 90 watt receiver (excluding the 254 has preouts). He said basically the same thing...the HK is conservative in the rating, their 50 watts is better than the Onkyo's 90 WPC. So...how do I, with a modest budget, decide? I thought watts was the first thing to look at. Again, obviously if I were choosing a 1,000 + dollar receiver, I would hear a big difference. I'm not sure what the differences are between these two budget receivers, and how to consider wattage. How do I know if it's 50 'conservative' watts, as opposed to 90 WPC that really isn't 90 WPC.
    Pycroft
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • Dawgfish
    That's a really good question. The best thing to do is to try to get out and actually listen to the recievers you are interested in. It would be even better if you could listen to them in your room using your speakers during a trial or looner period, but this rarely happens. There are articles which actually provide the results of actual bench tests on respective amplifiers. Do a google search for bench tests of the recievers you are looking at and you can see the results for yourself. This board is also a great resource. There are lot's of knowledgeble folks here with lots of experience.
    As far as the HK 254 goes, it's a great sounding AVR with preouts. Unfortunately some of these have had many problems and reliabiliy issues. If you can find a good one, they are an outstanding entry to lower-mid AVR. The amplifiers on the 254 will hang with the 606 with no sweat. It's just a matter of not finding one with reliability issues. If I were to buy one, I would make sure I got one from an authorized HK dealer, or a refurbished unit directly form HK, that way you would still have a warranty if anything went wrong.
  • jolax73
    jolax73 Posts: 225
    After reading all the thread in the forums and getting advice from you audiophile manias, I have set my mind to get the Emotiva XPA-5 as an external amp to drive my LSi speakers as I am planning to do a 5.1 setup.
    However, I am still in a dilemma in choosing which AVR or pre-processor to go along with my XPA-5. I want an AVR that cost around $500 but has HD radio, good video processing and be able to decode most HD sounds. Don't really need other best and whistles but for sure is reliable. I have read that Onkyo's AVR is kinda hot when being used so I would want to avoid that Brand. Just my opinion, no offend to Onkyo fans. I am inclining to Marantz, Denon or Yamaha but is also open to other suggestions. Not quite sure about Pioneer as I have never a big fan of Pioneer as their sound tends to be on the bright side.
    In addition, I notice that most AVR has a THD between 0.05-0.08% while with XPA-5, it's THD is 0.01%. So I must say it should have a cleaner sound output than using an AVR that cost above $1000. It is just my opinion that I could get a better sound using a separate Amp + $500 AVR than a $1200 AVR. Anyone agree?
  • Falcon01
    Falcon01 Posts: 89
    Depends on the AVR+AMP combination, wires between the two, etc but yes genereally going seperates gives you better sound. XPA-5's get good reviews from people that go from just an AVR to adding an amp but it also depends on the AVR. Some AVR's have great internal amplification so the difference may not be so drastic.
    Pioneer 50" Plasma (PDP 5080 HD)
    Pioneer Elite VSX-01
    Panasonic BD35
    PS3
    Monster MP HTS1600 Power Conditioner
    Paradigm Monitor 7's v3 (Front)
    Paradigm CC370 v3 (Center)
    Paradigm ADP 370's v2 (Surround)
    Polk Audio Rti4's (Back)
    Paradigm PW 2100 V2 (Sub)
    Coming Soon: 5 channel or 7 channel amp.
  • jolax73
    jolax73 Posts: 225
    What would be a comparable AVR to a Amp+XPA-5 combination with say other factors being the same? And what about price wise, do you think it would be more expensive to get a stand alone AVR that has the same sound quality to a combination AVR ($500) + XPA-5?
  • concealer404
    concealer404 Posts: 7,440
    I don't really know of any AVRs off the top of my head that truly put out the power that the XPA-5 is capable of, so i'm going to go ahead and say that it's probably not real possible on a similar budget of what it would cost for a decent AVR with pre-outs + XPA-5.
  • ls7z06
    ls7z06 Posts: 95
    Yes, I know all too well that watts are not the end all in receiver selection. But it is a definate consideration and one of the first things I look at. I also know there are better receivers than an Onk 806. I bought mine based on features, capabilities, specs, cost, and how it actually sounded with my other equipment, in my own home compared to other comparably priced products. (Thanks to Crutchfield's easy return policy)
    I have been pleased and think it sounds killer with my set up. It is very realistic and crystal clear at any reasonable volume level. When I considered the whole what you get for what you pay scenario, it was the best I could find. I may get an amp or even upgrade to an Elite or high end Denon or ??? one of these days. But I am real happy with the Onk so far.
  • jolax73
    jolax73 Posts: 225
    Anyone can give their recommendation for a decent (midrange) receiver that cost under $500 and also has pre-outs? I might also want to have the HD radio feature built-in.
  • jinjuku
    jinjuku Posts: 1,523
    jolax73 wrote: »
    If you are bypassing the Onkyo amp section you won't have to worry about the heat. The amp is what generates that heat.
    Onkyo is nice because of the Audyssey EQ system.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    My oinkers amp section is still active and is hot even though I do not use it so its certainly toasty and should have adequate ventilation, not to pick on Onk my H&K and Sony did the same, I have found the Parasound Z-breeze product as an excellent option to extend the life of an receiver/amplfier.
    RT1
  • ls7z06
    ls7z06 Posts: 95
    jolax73 wrote: »
    OMG! That's like saying you don't want a new ZR1 Corvette because you can't put your hand on the exhaust after you drive it. I have had Sony, Pioneer, Yamaha, Denon and Onkyo receivers. They all generate a certain amount of heat. But good luck in your quest! Let us know how you end up.
  • Krazyz1
    Krazyz1 Posts: 256
    Onkyo!!!!! untill it would break under warranty , and if thats the case just junk it. Onkyo customer service does not exist. Kinda like pay-pal. NEVER wrong. The good side is VERY LOW percentage of ONKYO defective. They have built theyre reputation on innovation and quality.
