Tube Buffers; Yaqin CD-1 & Musical Fidelity X-10v3
24
  • inspiredsports
    inspiredsports Posts: 5,502
    edited September 2009
    I was waylaid for a day or two sorting out a computer virus that invaded several of a client's computers, but was still able to listen daily. So finally, here it is . . .
    I am basically reviewing the Yaqin tube buffer "in reverse". That is, I've listened to my system using ("TT2" from post #30 above), my Thorens TD-160 BC Mk II with Infinity Black Widow Tonearm and Shure V15 Type IV Era IV as the "source" for about 200 hours. I then REMOVED the Yaqin CD-1 (it was located between my NAD preamp and amp) and listened again.
    First, the Yaqin came to me from eBay seller seiya.lee for $118.00 USD delivered. I paid by PayPal on Tuesday, September 1 very late in the day (11:30 PM EST). The unit arrived on the 9th (with the Labor Day Holiday in between) so it basically took 1 week to get here from Hong Kong. Pretty Amazing.
    The unit came with one 6N1 Chinese tube, plus an extra 6H1 Russian tube ("H" is substituted for "N" in the Russian/Cyrillic alphabet that does not have the letter "N"), a brief owners manual, a decent 5' IEC grounded power cord (European male end) and a European to US 3 Prong male adapter.
    Before applying power, I replaced the 6N1 tube with a new $20 JAN Phillips 6922 Green Label, and the supplied power cord with a 6' Signal Cable MagicPower.
    The unit is 4-3/8" deep by 7" wide by 5-1/8" tall and weighs 5.75 pounds (the power cable outweighs it, and the 2 MIT 2 Meter Shotgun IC's outweigh it once again which made me work a bit to get the cable management right). The unit sits on 4 good quality small rubber feet. It is very well made.
    The mostly black unit (top of approx 3" X 4" X 3" power transformer is tasteful brushed aluminum) features a convenient, decent quality on/off switch on the left side. The center of the 2-1/8" X 7" clear plexiglas-over-black faceplate lights up the Yaqin logo in bright blue. Cool, but a little overdone (too bright) for my taste; a small piece of black electrical tape gently applied over 90% of the logo made it more agreeable to my sensibilities.
    IEC Power in on the back and gold plated RCA L&R Inputs and Outputs complete the offering.
    RESULTS OF THE FIRST LISTENING TESTS USING a Turntable:
    I did both long duration (day long) and short interval A/B testing. I can lift the needle mid song, shut down the output, and swap cables to take the Yaqin out of the loop in seconds and then power up and drop the needle right where I left off. Without the Yaqin, the sound is still very good, but . . .
    1) There is distinctly less focus of the "phantom" center channel where the lead singer's voice on most rock LP's appears to originate. The pinpoint is no longer focused, but seems to originate from a larger area, perhaps 3 feet in diameter versus less than a foot in diameter.
    2) The apparent location of the phantom center channel was about 3 to 4 (or even more) feet in front of the plane of the speakers and has "moved back" to where it appears to come from approximately the plane of the speakers.
    3) The width of the soundstage diminished from perhaps 4 feet beyond the outside edges of the speakers to just over 2 feet beyond the outside edge of the speakers.
    4) The depth of the soundstage extended from the plane of the speakers to more than 5 feet out from that plane with the Yaqin in place, and dropped back by to between 2 and 3 feet with the Yaqun removed.
    5) The overall sound quality remained very consistent, but voices, snares, instruments, (especially snares, bells, cymbals, etc.) are much extremely focused and apparent with the Yaqin in place.
    6) THE BOTTOM LINE: I found the music to be much more "in my head" with the tube buffer working its magic and when it had been removed, I ALWAYS wanted it back!
    STOCK POWER CABLE TEST: The sound quality did not lose much using the supplied stock power cord and it made me think twice about the need for a $60+ power cable. The focus of the phantom center channel was diminished by a bit and dropped back toward the wall. The soundstage witdth just barely narrowed, but the overall depth and impact of the soundstage did not noticeably change.
    To be complete, someday I should come back and review the stock 6N1 tube, but I doubt that I ever will. I am in the process of acquiring Telefunken, Mullard and Siemans 6922/6DJ8/ECC88 tubes.
    The LP's: (*LP's are "mint" or "near mint" and most of each LP was listened to with Buffer BOTH in and out of the circuit)
    Bad Company; *Bad Company
    Deep Purple; *Machinehead, Stormbringer
    Dire Straits; *Brothers In Arms
    Genesis; The Lamb Lies Down On Broadway, * Trick Of The Tail
    Jethro Tull; Best Of Tul - Vol. II, *Crest Of A Knave, *Heavy Horses, Songs From The Wood
    Led Zeppelin; *Presence, Led Zeppelin I, II, III, IV
    Metallica; *Metallica (1991)
    Paul Simon; *Graceland
    Pink Floyd; *Dark Side Of The Moon, The Wall
    Roger Daltrey; Parting Should Be Painless, Ride A Rock Horse, Roger Daltrey, Under a Raging Moon
    Roxy Music; Manifesto
    Rush; All The World's A Stage
    Steely Dan; Aja, *Gold
    The Doobie Brothers; *Best of the Doobies, Livin' On The Fault Line, Minute By Minute
    The B52's - The B52's
    The Hollies; *Greatest Hits
    The HoneyDrippers; *Volume 1
    The Kings; *The Kings Are Here
    The Kinks; State Of Confusion, Low Budget, Give The People What They Want - Dave Daies; *GlamourTraffic; Best of Traffic
    Velvet Revolver; *Contraband
    Yes; *Fragile
    not my "cup of tea" but good critical listening
    Al Stewart; *The Year Of The Cat
    Bob James; *Obsession
    Concertgebouw Orchestra Of Amsterdam - George Szell; *Dvorak Symphony No. 8 in G Major, Op. 88
    Linda Rondstadt; Mad Love
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Dawgfish
    Dawgfish Posts: 2,554
    Great Review,
    As I read your review I was basically here talking to myself saying stuff like "yep", "me too", "exactly", "yeah that's what I noticed too", etc. I still have a long ways to go to break everything in, but I too find myself wanting to turn it back on immediately after turning the unit off. Music is just well, more musical! My system has a much increased sense of realism now. I am noticing increased detail throughout the frequency range, much better imaging, and a wider and deeper soundstage. The only negative I am getting right now is I get a little bit of sibelence (sp?) on some vocal tracks. I am fairly certain that this is due to the fact that I am simultaneously breaking in new interconnects, new speaker wire, and new tubes. The overall tone has warmed an apreciable bit. I can't wait to here this thing with the Mullards, tube dampers, and after having everything properly broken in. Stay tuned, more reviews to follow!
  • inspiredsports
    I should be able to critique the Yaqin with the CD sources over the next couple of days.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    As above, I've determined that I like the way my systems sounds when using a turntable with the Yaqin CD-1 tube buffer in place better than without. The overall sound quality is better, the soundstage both deeper and wider, the focus of the phantom center channel and specific instruments much more "pinpointed" and the apparent channel separation greater.
    I've now been listening for over 40 hour with and without the Yaqin between my NAD 5425 CD Player and preamp.
    The 5425 was rated by Hi-Fi World and others as one of the "most musical" CD players available when was introduced in early 1992. It's Frequency Response curve is dead flat to 14,000Hz, and it tails off just a fraction of a db from 14,000Hz to 25,000Hz. Distortion is less than .03% in the audible range. It's a 4X oversampled, 18 bit DAC unit with a 100db dynamic range, a signal to noise ration of 110db, channel separation of 90+db and boasts "unmeasurable" wow and flutter.I paid $295 for my first one in January of 1992, and bought a second in 2008 on eBay for $11 (they generally go for $85) because the 18 Volt axial lamp that illuminmates the control panel had burned out and the owner thought it was dead. $3 and a couple of dots of solder later I had 2 perfectly functioning units. Both are close in serial number and sound identical.
    The story is basically the same as with a turntable as a source. The size of the soundstage is magnified with the Yaqin in place, although not quite as large as noted in my turntable review above. The quality of the sound is also better and the pinpoint placement of voices and specific instruments within the soundstage was the same as with a turntable source.
    Short and sweet (and again as with a turntable source) when the tube buffer was out of the loop, I wanted it back in!
    What is most impressive to me is how the tube buffer opens up the soundstage. Even at low volume the soundstage is projects forward and beyond the outside edges of the speakers and the point from which vocals and individual instruments eminate is more tightly focused. As a quick story, I listen to a lot of Jethro Tull music. When performaing or recording, front man Ian Anderson alternately sings and plays a flute in front of a dual microphone setup. A standard mic is located straight up on the stand at about his Adams Apple level, and second a foot lower and to the right to capture his flute. He's quite animated when playing the flute and at times and marches in place, changing the location of his flute in relation to the 2 mics. With the Yaqin in place I can better discern that movement of the sound source.
    Tull Fans: Ian Anderson solo tour - Fall '09; http://www.jethrotull.com/tourdates/index.html#iausa)
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    The numerous products in the Musical Fidelity "V3"product line in general are said to not come alive until you add the Musical Fidelity X-PSU-V3 Power Supply Unit. The trouble is, these power units are no longer in production, and they never seem to be available on the secondary market.
    Well, a couple days of googling and it became evident that Mike G. at RockGrotto.com (in Scotland) knew that to be the case, and he set out to solve the problem with his custom made "Little Pinkie" power supply.
    At less than half the original cost of a new Musical Fidelity V3 power supply, owner's of the Little Pinkie claim it to be an even better sounding solution, right out of the box.
    My Little Pinkie arrived earlier today and has been in use for about 5 hours now. I've never listened to my Musical Fidelity X-10v3 Tube Buffer with anything but the original "wall wort" power supply (I almost aptly typoed "poser supply"), and it sounded excellent, but I've got to share that this thing takes the Musical Fidelity Tube Buffer to a whole new level.
    This Musical Fidelity versus Yaqin shootout is about to get very interesting.
    I'll reserve final comment until I've let the Little Pinkie simmer for a few days and do the formal listening, but the Yaqin that had been the better sounding of the two may be in trouble now.
    I wish I was able to attend the upcoming PolkFest as this is one of those things you can demonstrate in a heartbeat.
    NAD SS rigs w/mods
    GIK panels
  • Dawgfish
    Thanks for the update. I'll be intersted to here the comparison. Just a quick question, can the "little pinky" be used on the Yaqin also? If so I might want to check it out (for my Grant B-283, made by Yaqin). Also it wouild be good to use on both of the units (if possible) just so you have an apples to apples comparison.
  • ben62670
    ben62670 Posts: 15,969
    Does the little pinky plug in where the wall wort plugs in? What is the voltage on the wal wort for the MF, and the little pinky?
    Ben
  • inspiredsports
    The Musical Fidelity buffer has a 3-pin female DIN connection to receive 24volt AC power from an external power source where the Yaquin has a 110V female IEC connector to power it's internal power supply. The Little Pinkie would not work with the Yaqin.
    There is the opinion expressed in some forums that if you solder in a 33uF/400V electrolytic cap between the hot (+) and the ground wires within the CD-1, it will yield tighter bass and bottom end and accuracy and improve overall musicality. I will be experimenting with adding this cap to my Yaqin in the near future.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    ben62670 wrote: »
    The Musical Fidelity wall wort is 24 Volts AC, 500mA and the Little Pinkie is 30 Volts AC, 2500mA. I guess voltage regulation happens inside of the Musical Fidelity buffer. Both power supplies have a cord ending with a male 3-pin DIN connection that mates with the Musical Fidelity buffer's female 3-pin DIN receptacle.
    NAD SS rigs w/mods
    GIK panels
    heiney9 Posts: 25,451
    I'm curious how you came to substituite a 6922 for 6N1? I have a Dared MP5 integrated hybrid amp that uses (2) 6N1's for the input buffer. I was told that anything in the 6DJ8 family (which the 6922 is) could most likely do damage to the tranny or internal parts so I've avoided using those. Russians make a superb 6N1P-EV and 6AQ8/ECC85 can be subbed as well. I have several early 60's era 6AQ8/ECC85 from Heerlen, Blackburn, West Germany (Siemens) as well as Telefunken's that are simply amazing sounding tubes.
    In the future you may want to try and hunt one of these down and try them(6AQ8/ECC85). Did the manufacturer suggest the 6922? I'm half tempted to try a 6DJ8 variant for **** and grins.
  • inspiredsports
    Yaqin prints this near the tube socket on every model CD-1 they produce
    V V V V V V
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    heiney9 wrote: »
    I'd done hours of research and read the JAN Phillips 6922 Green Label was really inexpensive for what you get (and in the 6DJ8/6922/ECC88 family) so I thought I'd give it a try. It's been great so far, and I did plug in the Chinese 6N1 provided for about 5 hours. This particular 6N1 really sounds inferior, although I guess I should give it a few days to be totally fair.
    I sure hope this class of tube doesn't cause a catastrophic shower of sparks because I just ordered a NOS Bugle Boy Amperex Holland 6DJ8/6922/E88CC to try out next.
    I've heard great things about Dared, but don't know enough about how power supplies and tubes relate to one another. It sure seems there are a lot of high-line 6DJ8/6922/ECC88 options out there to make it worth researching.
    NAD SS rigs w/mods
    GIK panels
    I have yet to hear a Chinese tube that sounds any good even compared to an el cheapo Russian/American/European variant. All Chinese tubes supplied as OEM with these types of units sound really inferior.
    I don;t know enough either about the design of the Dared MP5 I have heard it's a very robust unit and some have been experimenting with 6DJ8 family of tubes. The "American" version of the MP5 strangely enough will allow for 6DJ8 family tube rolling.
    I also have a Dared Sl2000A pre-amp with the Auricap upgrade. It is a simply stunning sounding tubed pre-amp. It takes (2) 12AT7/ECC81 along with a 5Z4 rectifier tube. I have been using all kinds of 12AT7 variants as well as a 5V4 and 5Y3 rectifier. The differences in tubes and rectifiers is fun to mess around with.
    In the Sl2000A I've used
    12AT7
    ECC81
    E81CC
    5965
    6414
    7062
    6201
    6211
    6829
    7728
    E180CC
    From every possible manufacturing site. Germany, West Germany, Blackburn, Heerlen, Hamburg, France, Holland.
    It's been great fun and I'm starting to narrow down my favorites, although I have a bunch of excess tubes to sell.
    Sounds like you're having fun as well.
  • inspiredsports
    heiney9 wrote: »
    . . . sounds ike you're having fun as well.
    It's true! (and it guys like you into tubing that did this to me :D)
    This morning is a classic example. I'm self-employed and work from home so I can shift my schedule, but I got into my home office at 7:30 this morning to catch up on some paperwork.
    That was more than 3 hours ago and all I have done is listen to music and **** around on the Internet and here at Club Polk. :)
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    And now the plot thickens once again. I just received and installed a NOS Bugle Boy Amperex (Holland) 6DJ8/E88CC in the Yaqin. I paid just a tiny fraction of what this sometimes $120 tube goes for in a no reserve auction when no one else bid!
    This tube is pure heaven. I always KNOW when I've found gold when my wife peeks over my shoulder and says, "Is something new? That sounds good". Then she whispers stuff I'm not gonna share :D
    BINGO!
    This soundstage is BESIDE ME, and I'm fourteen friggen feet back from the front of the speakers! You'll have to excuse me, but I'm having a hallucinogenic moment. My SDA's have NEVER done this before!:):):):):):):)
    NAD SS rigs w/mods
    GIK panels
  • Jetmaker737
    Jetmaker737 Posts: 1,120
    Hi, I've been lurking in this thread. It's a really interesting idea, these tube buffers. But does anybody besides me harbor doubts about these cheap Chinese Yaquin things? Is there a history on them to give you confidence?
  • inspiredsports
    Great question, and that is PRECISELY why I'm critiquing the Yaqin side by side against the benchmark Musical Fidelity X-10v3 with a proven track record.
    I read one specific passage (albeit on the Internet where you can't be certain) that stated, "The Yaqin's power supply is the same as is used by at least one tube preamp manufacturer in a preamp that sells for over $2000."
    So far the Yaqin's performance has been stellar.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    Forgot to write it above; Welcome Aboard Jetmaker737! :)
    NAD SS rigs w/mods
    GIK panels
  • Jetmaker737
    Thanks for blazing the trail, man!
  • DollarDave
    DollarDave Posts: 2,575
    I've had a Yaqin for several years now (thanks RuSsMaN) and it has been solid. Once this review is complete, I think I will try some tubes that might kick it up a notch from the GE's that I am using now. The GE's were a step up from the stock tubes.
    The thing with Chinese tube gear is really have to look at the parts selection and circuit design as well as what tubes they decided to use. There are some stunning sleepers that come from China. Always.....always replace the Chinese OEM tubes with something much better.
    I have (2) Dared pieces an integrated tube/hybrid amp and pre-amp. The build quality and parts used are top notch, add the proper tubes and it will blow you away. I am amazed at how good the pre-amp sounds. (Sl2000A)
    They use Nichicon caps, Allen Brady resistors and very expensive well regarded Auricaps for coupling caps. A very strong transformer and with the right vintage rectifier tube (1950's Sylvania black plate) and 12AT7/ECC81 tubes (I prefer 60's telefunken or 50's Valvo) this things sounds fantastic.
    But.............not all Chinese gear is like that there are some real clunkers out there. I've read mixed reviews on the Yaqin both very positive and just average.
  • Jetmaker737
    The Musical FidelityX-10 is rated at <.004% THD 10 Hz - 20 kHz. The Yaqin is rated < .15% at 1 kHz. Is this a concern? And is there an advantage/disadvantage to the two-tube Yaqin CD2?
  • ben62670
    I am confused. You linked back to the same thread?
    Ben
  • inspiredsports
    Resetting the stage:
    Here's the test platform for as near a perfect A/B test between the Yaqin CD-1 Tube Buffer and Musical Fideity X-10v3 Tube Buffer as I could design with the equipment I own.
    Symmetrical 20' X 26' Finished basement with padded carpet over concrete floor and 8' height ceiling with 2'X4' insulated drop ceiling panels.
    20' painted block wall behind speakers. Insulated stud wall with wood paneling on other 3 walls. Typical furnishings with mix of leather sofa/chairs and wood tables, entertainment center, shelving placed approximately equally from center-line of speakers.
    Speaker backs are 7" from rear wall. Speaker sides are 3' from paneled side walls. Speakers are 21" wide leaving 10'-6" between inside edges of speakers. This puts speaker center-lines approximately 12'-6" apart.
    Listening position is dead center and 12'-6" back from front plane of speakers.
    --- All components powered by APC H10 Blk
    --- 5' Groneberg Quatro Reference Power Cable from ABC to wall outlet. Wall standard duplex outlet is 10' run of Romex from dedicated 20A breaker in adjacent breaker box.
    --- Modded Polk SDA SRS "2.1 TL's" with Cardas Binding Posts
    --- 10' MIT Shotgun S2 Speaker Interface Cables (bananas all ends) to pre-amp
    --- NAD 1700 Pre-amp (Rebuilt Caps, Power Section, Cardas Binding Posts)
    --- 2M MIT Shotgun S2's with Adjustable Impedance Boxes with Locking RCA's from pre-amp to Power Amp
    --- NAD 2600A Power Amp (Rebuilt Caps, Power Section and Cardas Binding Posts)
    --- Pre-amp "CD" input from CDP1
    --- Pre-amp "Aux" input from CDP2
    --- CD Players both similar vintage 1992 and serial numbers within a couple thousand of one another.
    CDP1 --- NAD 5425 --- standard 110V power cord to APC H10
    --- 2M MIT Shotgun S2's with Adjustable Impedance Boxes with Locking RCA's from CDP1 to tube buffer
    --- Musical Fidelity X-10v3 Tube Buffer with 2M MIT Shotgun S2's with Adjustable Impedance Boxes with Locking RCA's to pre-amp
    --- Musical Fidelity female DIN power reseptacle connected to "Little Pinkie" 30VAC 2500mA custom power supply
    --- Little Pinkie connected to APC H10 with 5' Shunyata Diamondback Platinum Power Cable
    CDP2 --- NAD 5425 --- standard 110V power cord to APC H10
    --- Yaqin CD-1 Tube Buffer with 2M MIT Shotgun S2's with Adjustable Impedance Boxes with Locking RCA's to pre-amp
    --- Yaqin CD-1 previously tested with NOS JAN Phillips 6922 Green Label and NOS Amperex (Holland) 6922 and Amperex won and will be used.
    --- Yaqin CD-1 connected to APC H10 with 5' Shunyata Diamondback Platinum Power Cable
    All components and connecting wires have been connected and energized long enough that I deem any synergies possible have been established.
    I've found this to be an exceptionally good test bed where I can make component substitutions and immediately hear the results.
    I have a few duplicate CD's that can be placed in the CD players.
    The CD players are remote control, and both will work from a single remote
    Pressing "Play" starts both CD players within a few milliseconds or one another, and remarkably, they are still with a fraction of a second at the end of the last tracks on the CD's
    The NAD pre-amp is remote control and switch from "CD" input to "Aux" input is quiet and nearly instantaneous.
    I have pre-listened to both CD players, swapping them to both pre-amp inputs, and to my ear their respective sound qualities are indistinguishable from one another.
    Duplicate CD's I own in no specific order that I used for testing
    Paul Simon; Graceland
    Genesis; We Can't Dance
    Pink Floyd; The Dark Side Of The Moon
    Eric Clapton; Timepiece: The Best Of Eric Clapton
    David Bowie; The Rise And Fall Of Ziggy Stardust And The Spiders From Mars
    RESULTS OF THE LISTENING TESTS USING CD Players
    I conducted both long duration and short interval A/B testing (by pressing the "CD" or "Aux" buttons on the NAD remote).
    I listened tube buffers OUT OF THE LOOP for 2 DAYS, and then IN THE LOOP FOR 3 DAYS.
    Without the tube buffers, the sound is still very good as you would expect from a decently powered and cabled SDA system.
    WITH the tube buffers in place and listening to EITHER tube buffer ...
    1) The focus of the "phantom" center channel becomes "laser-like" and I literally felt the sense of sound pressure emanating from an 8" high by 20" deep X 24" wide cubbyhole in my entertainment center located at the center-line of the speakers.
    2) As in the LP testing, I found the apparent location of the phantom center channel to be 3 to 4 (or even more) feet in front of the plane of the front plane of the speakers.
    3) The width of the soundstage is essentially the entire 20' width and most of the 8' height of the back wall.
    4) The depth of the soundstage extended from the plane of the speakers to an astonishing 12 feet out the side walls from that front plane of the speakers.
    5) The overall sound quality remained very consistent, but voices, snares, instruments, are more extremely focused with what I term more "air around them"
    Using an overall scale consisting of 100 points, if I were to assign the Musical Fidelity X-10v3 a "95", I would assign the Yaqin CD-1 an "88" to a "90".
    Listening to all of the various types of music I had available, in each case the dimension of the soundstage thrown out by the Musical Fidelity X-10 was slightly larger. And I mean only slightly, but using the A/B ability of the remote control switch from "CD" to "Aux", it was possible to pinpoint even tiny apparent location shifts for any voice or instrument.
    The size and focus of the soundstage, however, was so small that it did not account for my 5 out of 100 point difference call. The sound quality of the Musical Fidelity buffer was as best as I can describe it in words, "clearer"/"airier"/"less veiled" by a small margin, but I preferred it. This is one of those incredibly subjective calls, but at this point if I could choose only one, The Musical Fidelity X-10v3 Tube Buffer would stay.
    One extremely important observation I made was that the power output LED's on the APC (which are incremented 20%, 40%, 60%, 80%, 100%, 120%) ALWAYS stayed on 20% with the Yaqin. On just a few of the most POWERFUL MUSIC PASSAGES, the Musical Fidelity would move the power usage to the 40% LED. I have to believe the Musical Fidelity was able to allow more current to pass to the drivers. The sound volume was not specifically louder, but there was an overall perceived enhanced sound quality.
    Now, as far as cost, this is an incredibly unfair test.
    First, lets' be blunt, I'm using TWO $800 each (list price) Interconnect Cables & ONE $250 each (list price) power cable PER buffer to insure their top abilities (or deficiencies) are revealed.
    Netting OUT the $1,850 (at retail) cable value, the delivered value of the brand new in box Yaqin ($118) plus the $100+ value Amperex vacuum tube I snagged for $20 off of eBay and the $20 value of a Herbies Ti-9 Tube Damper put the net delivered total value of the Yaqin CD-1 as tested at $158.00 USD.
    Netting OUT the $1,850 (at retail) cable value, the delivered value of the vintage Musical Fidelity X-10v3 ($200) plus $219 delivered price of the brand new Little Pinkie Power Supply put the net delivered total value of the Musical Fidelity X-10v3 at $418 USD.
    At least three good questions could be asked:
    1) Can Greg's subjective ears be trusted to determine the two units are about 5% or so apart?
    2) If the answer to Question #1 is "yes"; Would the units compare in the same way if "free" or "almost free" power cables and interconnects were used?
    3) If all comparisons remain the same with lesser cabling, is it worth spending $260 more ($418 - $158) to get a 5%-7% increase in sound quality?
    IMPORTANT NOTES:
    -- The Musical Fidelity's wall wort power brick could probably be sold for $30 USD to reduce the price differential.
    -- The Yaqin's ($158) sound quality was BETTER than the Musical Fidelity's at $200 before the upgraded Little Pinkie power supply was added.
    -- There is supposedly a power supply improvement that can be made to the Yaqin by soldering a high grade 33uF ($60 for 3 X 11uf 200VDC Sonicap) electrolytic cap from the positve side of the power rail to ground. I will be performing this mod within the next 4-5 weeks and will POST AN UPDATE AS TO A/B SOUND QUALITY IMPRESSIONS.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    This noise difference might be what I am picking up in my overall impression of the Yaqin in Post # 64 above as the Yaqin overall sound quality sounds just a bit more "veiled".
    I will report again when I complete the Yaqin power upgrade and listen, but If I use Sonicaps, it will take perhaps 150 hours of burn in.
    NAD SS rigs w/mods
    GIK panels
  • hearingimpared
    hearingimpared Posts: 21,136
    Awesome work and very detailed write up Greg. I'm glad the tube buffers made such a dramatic difference in your rig. Much happy listening.
  • inspiredsports
    Keiko wrote: »
    Whew! Brudduh Greg, you into it good and got it bad. :D Think if I send you my Yaq you could mod it for me? :p jk ;)
    Hey Mike, I owe you, so, . . . absolutely! :)
    (I do want to get the first one under my belt)
    I would certainly appreciate it if those with more experience than I could weigh as I am trusting just one post I read that a decent quality 33uf electrolytic is a good choice and if 3 X 11uf 200VDC Sonicaps would work as well as the 33uf/400VDC Epcos he used.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    Joe, the day I snapped up your MF buffer turned out to be one of the best days of my audio related life. As you might have read, the power source is what unlocked its potential.
    Now I'm afraid (well actually more like EXCITED :D) that my future will be laden with days of shopping for, the buying of, excitedly waiting for (like Christmas morning), installation of, and tube rolling of many, many pieces of tube pre-amps and ultimately amps.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    I missed your CD-2 question when I answered the distortion question.
    Keiko's had great results with his 2 tube unit. It uses a pair of a different tube model where the price of pairs are about on par with the price of singles that the CD-1 uses.
    I'm new at this, but from what I've seen, I perceive there are more of the 2-tube pairs out there so you probably get a better selection of great tube pairs.
    On the other hand, the sound quality of many 6922/6DJ8/ECC88's that the single tube CD-1 uses seem to be highly prized, and priced accordingly.
    NAD SS rigs w/mods
    GIK panels
  • Jetmaker737
    Awesome test and write-up Inspired! You've really laid out the pros/cons of the MF and Yaqin.
    This thread introduced me to the existence of tube buffers right when I was shopping for a pre-amp and considering a tube pre. But I stumbled onto a good deal on a Parasound 2100 and couldn't pass it up. Now I'm really leaning towards a buffer to try out the tube sound in my system... appreciate all this great info!
