Integrated vs AVR
Systems
Forgive my ignorance, but what is the difference between an integrated amp and an AVR?
Testing
Testing
Testing
Testing
Testing
An integrated amp will simply let you connect multiple sources to it. It normally has no advanced features such as surround sound decoding/EQ/AM/FM Tuner etc... You would supply all of that.
Hope this helps -
Generally the AVR is used in a HT type set-up, the integrated amps are mostly used in two-channel stereo rigs, some integrated pieces have an HT-bypass which allows the piece to be used within an HT rig when listening to music in stereo, integrated amps/components offer better sound quality for stereo, while the AVR=Audio/Video Reciever for your HT rig where subtle musical nuances, dynamics, space, soundstage and such words used by audio 2-channel lovers to describe the musical recording are less important with the FX effects found in todays soundtracks which the AVR excels in decoding. That said there is a very wide range of gear available in both areas where the lines become less obvious, but generally the costs go way up. Two-channel receivers are also available which offer Tuners are also available these are at times also referred to as integrated receivers.
RT1
