Looking for replacement tweeter SL6502 BD0123 for RTi 3000p
Hamsterman
I might need a replacement tweeter for a RTi 3000p
It would be a SL 6502 tweeter - BD0123.
Anybody have one? Or is there a comparable tweeter I could replace it with.
Picked these speakers up used, currently the one I have looks like this - and I figure that is not good
Post edited by Hamsterman on
looking at the tweeter - does it look fried to you guys?
This looks like a recently blown pair of tweeters I have in my speakers of same model, and the tweeters were working before they let loose. I am understanding replacement tweeters are the SL6506, which have replaced the SL6502.
Have you replaced these tweeters yet? -
I believe one of the Dayton neo silk domes will drop in that spot. Just won't be silver.
What is the Dayton part # ?
Will it sound as good as the sl6502? -
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=275-040
It will sound good, and will definitely handle the crossover point. You'll want to check the fit. -
Not the same size
I'd look for a pair of cheap RT series speakers and salvage the tweets. Check out eBay.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers -
Can I make these work? Can I just screw them into the cabinet?
How about wattage,ohms, crossover? Are tehy the same? Thanks. -
