New 2-way speaker design
ShinAce
A friend of mine is finding himself in a new home and wants a 5.1 surround system for his living room.
1) Subs are covered.
2) Mains. I've been thinking the recession buster kit. Assuming the stock is still there, I'd build 4 of them and look at the center separately. I'm thinking of even buying the kit 6 times, leaving me with a spare tweeter and crossover. I would use D'appolitto's geometry to build the center with 2 woofers and add resistors to the woofers to keep the same load on the corssover and amp.
What else can you guys suggest? This guy is a neurosurgery resident, which means he has few hours to watch movies and doesn't even make that much money. I'm trying to keep it as cheap as possible without going to inferior quality.
It's mostly for music but will need to suffice for HT.
The space is average; roughly 12' x 15' .
Post edited by ShinAce on
If you call Madisound, they will sell you an odd number of kits.
I'm not sure if there are any RB kits left, but I believe they have plenty of the new RBR kits left, which may be over his budget. http://www.madisound.com/catalog/product_info.php?cPath=35_38_436&products_id=8644"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
There's also Zaph's new kits. I haven't heard any feedback on them yet, but there is one made specifically made to be used as a center channel.
http://www.madisound.com/catalog/advanced_search_result.php?keywords=zaph"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Just noticed the Vifa kit is sold out.
Zaph's ZA5.2 TM 2-Way looks pretty good. I'll run him through the cost of doing 2 sets of these plus the center channel.
I would gladly do the RB reference for myself, but not for him. There's no knowing if the speakers will still get use 2 years from now. He still needs to get himself a flat panel TV to boot. -
wow those crossovers are ridiculousHOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
I have a pair of ZMV5's http://www.polkaudio.com/forums/showthread.php?t=74167&highlight=METAL+MINI+MONITOR .The ZA5.2 is basically the ZMV5 with Zaphs custom version of the woofer and one .1uf cap added to the xover.
They are a good sounding little speaker but I found that the original MCM version of the woofer reached it's excursion limit's rather quickly (even for a 5") with any bass heavy conent even at normal listening levels.Zaph's updated version should be better in this regard but I think hi pass filtering and using sub will be mandatory for HT use.
Too bad the Vifa RB2 ' are sold out,I was considering getting another pair.Testing
Testing
Testing -
Sweet!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
That's my favorite tweeter next to the Be tweeter in Focal's Utopia line."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Considering the difference in price, I'd take the Air Circ's.That'd be a fun shootout.
Have you heard Usher's new BE tweeter? It starts on their rebuild of the Tiny Dancer and has only received great reviews.
No I haven't, there are no Usher dealers near me.
These look pretty interesting though: http://www.scan-speak.dk/datasheet/pdf/d3004_664000.pdf
Too bad the off axis response isn't better though."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Those off-axis charts are pretty steep, but it seems like that tweeter does have loads of potential.
Upon doing some more reading, AVguide claims that the MSRP of those new tweeters is $1000 a pair. :eek:
