DVD-A Creator?
zingo
Has anyone used a DVD-Audio burner, creator PC program? I have a lot of high resolution files (>44.1 kHz) that I'd love to be able to play off of my DVDp source, but haven't seen any programs that allow DVD-A to be burned instead of just the regular redbook CD. Any help would be great!
Post edited by zingo on
What's DVD-Audio?
DVD-Audio (commonly abbreviated as DVD-A) is a digital format for delivering high-fidelity audio content on a DVD. DVD-Audio is not intended to be a video delivery format and is not the same as video DVDs containing concert films or music videos. The first discs entered the marketplace in 2000. DVD-Audio was in a format war with Super Audio CD (SACD), another format for delivering high-fidelity audio content.
Zingo...I use Toast Titanium with an Apple G4. I can burn DVD "music" discs in DD up to 448 kbps or PCM 96 kHz/24 bit which are pretty good quality. I don't think there's anything available for consumer use that actually creates DVD-A type discs.
If your using Windows/PC, check out Windows DVD Maker or Nero.
Thanks. I'll check out those programs when I get home as see if they let me burn those music files onto a DVD. -
I have used Minnetonka's Disk Welder Bronze with good results.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
You could also tru dvdlab pro. I don't remember if it does or not. They do have a free trial you can download. just do a google for it.
