DVD-A Creator?
zingo
zingo Posts: 11,258
edited September 2009 in Electronics
Has anyone used a DVD-Audio burner, creator PC program? I have a lot of high resolution files (>44.1 kHz) that I'd love to be able to play off of my DVDp source, but haven't seen any programs that allow DVD-A to be burned instead of just the regular redbook CD. Any help would be great!
Post edited by zingo on
  • Barefoot
    Barefoot Posts: 149
    What's DVD-Audio?
  • zingo
    zingo Posts: 11,258
    DVD-Audio (commonly abbreviated as DVD-A) is a digital format for delivering high-fidelity audio content on a DVD. DVD-Audio is not intended to be a video delivery format and is not the same as video DVDs containing concert films or music videos. The first discs entered the marketplace in 2000. DVD-Audio was in a format war with Super Audio CD (SACD), another format for delivering high-fidelity audio content. :D
  • zingo
    zingo Posts: 11,258
    Keiko wrote: »
    Zingo...I use Toast Titanium with an Apple G4. I can burn DVD "music" discs in DD up to 448 kbps or PCM 96 kHz/24 bit which are pretty good quality. I don't think there's anything available for consumer use that actually creates DVD-A type discs.
    If your using Windows/PC, check out Windows DVD Maker or Nero.
    Thanks. I'll check out those programs when I get home as see if they let me burn those music files onto a DVD.
  • Fongolio
    Fongolio Posts: 3,516
    I have used Minnetonka's Disk Welder Bronze with good results.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dudeinaroom
    dudeinaroom Posts: 3,609
    You could also tru dvdlab pro. I don't remember if it does or not. They do have a free trial you can download. just do a google for it.
  • zingo
    zingo Posts: 11,258
    Thanks for all the suggestions!
